[Bug-11993] Webdev module not working in Beta
Where to download the 'dairy demo simulator' and the 'web dev module' from? Does it contain code for the sample?
WebDev Module is at the bottom of the Device Connectivity section here: Current Ignition Release | Inductive Automation
The ‘Dairy Demo Simulator’ is one of the built in simulators - in <=7.9 versions, it’s part of the Allen Bradley Drivers module, while in 8.0 it’s been moved into the OPC-UA module.
The downloaded version says 3.9.10, on installing it on Ignition 8, I get error "Faulted
Required Major Version Mismatch" ! Is it not compatible with Ignition 8? Which version is it compatible with ? How to download the version compatible with Ignition 8? Are there different versions of WebDev available for different versions of Ignition?
You need to use the 8.0 version of the module, available on the same beta downloads page: https://inductiveautomation.com/downloads/ignition-8-beta
Thanks it worked!
The version 3.9.10 is for which version(s) of Ignition?
The "WebDev" resource doesn't appear in the "project browser" window of New designer after Installing the WebDev version 8 in new designer!
Check your module is installed and running in the gateway... its working fine for me
Perhaps its the latest build. I haven't yet updated from my last month's build (around Nov 27). I will check it.
Thanks for the update.
best regards
No I don't seem to get the web dev module working! I just updated to latest build of Ignition 8!
Whereas the WebDev module is shown as Installed on configuration page!
Is there any thing mising!
Can you post the logs from the designer console? There may be an error with starting the module in the client scope.
Same is enclosed
22:03:11.386 [Designer-Startup] INFO designer.main - Downloading... [+0]
22:03:11.440 [Designer-Startup] INFO designer.main - Cleanup... [+54]
22:03:11.441 [Designer-Startup] INFO designer.main - Initializing UI... [+55]
22:03:11.588 [DesignerExecEngine-1] INFO tags.subscriptions - Changing connected quality to 'Good'
22:03:12.717 [Designer-Startup] INFO designer.main - Starting module: Vision [+1331]
22:03:17.573 [Designer-Startup] INFO designer.main - Starting module: Reporting [+6187]
22:03:17.651 [Designer-Startup] INFO reporting.Designer - Starting up Reporting Module. Mode: Trial
22:03:18.099 [Designer-Startup] INFO designer.main - Starting module: Alarm Notification [+6713]
22:03:18.245 [Designer-Startup] INFO designer.main - Starting module: WebDev [+6859]
22:03:18.250 [Designer-Startup] ERROR designer.main - Error starting up module WebDev
java.lang.ExceptionInInitializerError: null
at com.inductiveautomation.webdev.designer.DesignerHook.startup(DesignerHook.java:21)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$LoadedModule.startup(IgnitionDesigner.java:1977)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.startupModule(IgnitionDesigner.java:1108)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadProject(IgnitionDesigner.java:930)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$StartupProjectDialogHandler$1.run(IgnitionDesigner.java:2049)
Caused by: java.lang.NullPointerException: null
at com.inductiveautomation.ignition.designer.navtree.icon.NavTreeIcon.(NavTreeIcon.java:26)
at com.inductiveautomation.ignition.designer.navtree.icon.NavTreeIcon.createIcon(NavTreeIcon.java:54)
at com.inductiveautomation.webdev.designer.workspace.WebResourceWorkspace.(WebResourceWorkspace.java:49)
... 6 common frames omitted
22:03:18.251 [Designer-Startup] INFO designer.main - Starting module: Symbol Factory [+6865]
22:03:18.259 [Designer-Startup] INFO designer.main - Starting module: SFC [+6873]
22:03:19.633 [Designer-Startup] INFO designer.main - Starting module: Enterprise Administration [+8247]
22:03:19.654 [Designer-Startup] INFO designer.main - Starting module: DNP3 Driver [+8268]
22:03:19.655 [Designer-Startup] INFO designer.main - Starting module: SQL Bridge [+8268]
22:03:19.908 [Designer-Startup] INFO designer.main - Starting module: OpcCom [+8522]
22:03:19.909 [Designer-Startup] INFO designer.main - Starting module: Perspective [+8523]
22:03:20.059 [Designer-Startup] INFO Perspective.Designer - Starting up Perspective module. Mode: Trial
22:03:20.508 [Designer-Startup] INFO Perspective.ViewWorkspace - The cache path for this browser context is 'C:\Users\imex.ignition\cache\gw127.0.0.1_8088_main\C0\perspective'
22:03:21.668 [Designer-Startup] INFO Perspective.SessionProps - Session props debug url: http://localhost:9222/devtools/inspector.html?ws=localhost:9222/devtools/page/(2179B91876CFF07F315E4608CC72E56B)
22:03:21.922 [Designer-Startup] INFO designer.main - Initializing Scripting... [+10536]
22:03:22.011 [Designer-Startup] INFO designer.main - Initializing UI... [+10625]
22:03:22.054 [Designer-Startup] INFO com.inductiveautomation.ignition.designer.querybrowser.QueryBrowser - No default datasource set for project. Set default in gateway and relaunch project.
I uninstalled and reinstalled the webdev module but still it gives the null pointer error on designer console log .
Did you download a new WebDev module from the beta page? I don’t know if that’s included in the installer and your screenshot shows you’re running an older WebDev module than the rest of the modules.
I downloaded it from Download Ignition by Inductive Automation . The config page shows version as 4.0.0-beta0 (b2018121010)
Looks like a bug caused by a change we made to the icons. I’ve filed an internal ticket, and we’ll get it fixed soon.
Did you find any issues? I just upgraded the new build, but still gives the null pointer exception in the designer logs for the webdev module.
Incidently I get the following warning while installing the new build of Ignition 8 over the previous one:
Anything that I need to do? I tried restarting the module but error remains.
On upgrading to latest version of WebDev (4.0.0-beta0 (b2018121410)), it worked fine. Thanks
22:05:44.151 [Designer-Startup] INFO designer.main - Downloading... [+0]
22:05:44.229 [Designer-Startup] INFO designer.main - Cleanup... [+78]
22:05:44.229 [Designer-Startup] INFO designer.main - Initializing UI... [+78]
22:05:44.391 [DesignerExecEngine-1] INFO tags.subscriptions - Changing connected quality to 'Good'
22:05:46.013 [Designer-Startup] INFO designer.main - Starting module: Vision [+1862]
22:05:52.071 [Designer-Startup] INFO designer.main - Starting module: Reporting [+7920]
22:05:52.134 [Designer-Startup] INFO reporting.Designer - Starting up Reporting Module. Mode: Trial
22:05:52.522 [Designer-Startup] INFO designer.main - Starting module: Alarm Notification [+8371]
22:05:52.819 [Designer-Startup] INFO designer.main - Starting module: WebDev [+8668]
22:05:52.850 [Designer-Startup] INFO designer.main - Starting module: Symbol Factory [+8699]
22:05:52.866 [Designer-Startup] INFO designer.main - Starting module: SFC [+8715]
22:05:54.140 [Designer-Startup] INFO designer.main - Starting module: Enterprise Administration [+9989]
22:05:54.171 [Designer-Startup] INFO designer.main - Starting module: DNP3 Driver [+10020]
22:05:54.171 [Designer-Startup] INFO designer.main - Starting module: SQL Bridge [+10020]
22:05:54.546 [Designer-Startup] INFO designer.main - Starting module: OpcCom [+10395]
22:05:54.547 [Designer-Startup] INFO designer.main - Starting module: Perspective [+10396]
22:05:54.742 [Designer-Startup] INFO Perspective.Designer - Starting up Perspective module. Mode: Trial
22:05:55.054 [Designer-Startup] INFO Perspective.ViewWorkspace - The cache path for this browser context is 'C:\Users\imex.ignition\cache\gw127.0.0.1_8088_main\C0\perspective'
22:05:56.304 [Designer-Startup] INFO Perspective.SessionProps - Session props debug url: http://localhost:9222/devtools/inspector.html?ws=localhost:9222/devtools/page/(C40164FBA66442BD393B4D0B06E4D106)
22:05:56.802 [Designer-Startup] INFO designer.main - Initializing Scripting... [+12651]
22:05:56.927 [Designer-Startup] INFO designer.main - Initializing UI... [+12776]
22:05:56.959 [Designer-Startup] INFO com.inductiveautomation.ignition.designer.querybrowser.QueryBrowser - No default datasource set for project. Set default in gateway and relaunch project.
I wonder what are these number is brackets such as [+8668], [+8699] etc!
They are milliseconds since the launch started.
