Change column width of Table in Perspective
Right, I should have at least posted my script.
Here is what I have and it doesn't seem to work. Column "Val3" is the one I'm trying to edit, as you can see some of the string from column "val3" makes it's way into column "val4"
The width value is in column number 4 of the table properties. I also added the whiteSpace: nowrap property to the style.
table
