Combine two datasets
can you draw me on paper or paint or something what you/your boss actually wants?
because i think you and your boss are talking about a diffrent kind of offset. Or me idk
simple when i choose first tag . i am selecting time 4am to 5am. it will show data for that
if i select another tag i want to show data from 4.05am to 4.50 am
some difference between the first and second tag
So the offset is on the time?
yes correct. because time stamp column will be same for all tags so
dataSet1 = system.tag.queryTagHistory(paths=[‘Sine’], startDate=startTime1, endDate=endTime1, returnSize=1, aggregationMode=“Maximum”, returnFormat=‘Wide’)
dataSet2 = system.tag.queryTagHistory(paths=[‘Sine’], startDate=startTime2, endDate=endTime2, returnSize=1, aggregationMode=“Maximum”, returnFormat=‘Wide’)
Just change the times when you collect the dataset?
same thing i am doing. but when join dataset1 and dataset2 in to single dataset. i am getting this type of issue
yes collecting but i am to show them in single dataset not in different dataset
define “this type of issue”
like this
is the issue the blue line being so flat or the red line having holes?
holes in both red and bule see.
some space
which chart are you using? in vision or perspective?
in vision. normal chart
vision has a chart customiser.
I suppose you need
Dataset Properties Tab:
Renderer XY Line/Shape Render
Type Lines Only
you can look here i suppose you want something like the date axis chart example
https://docs.inductiveautomation.com/display/DOC81/Vision+-+Chart+Customizer
if that doesnt work you should probably make a new topic
Actually i am using this only XY Line/Shape Render
same type Line only
i suppose its having some trouble with the null’s that have been added in
you should make a new topic. Im not familiar enough with vision charts.
Ok thanks for the time
