Combining Modbus Registers Indirectly
What is the exact expression you were using? Do you have the high and low words brought in as OPC tags already, and you're now just creating a 3rd expression tag to combine them?
P.S. the float case is tricky and can't be done with the expression language alone: 64-Bit Double Little Endian Input Register - #25 by Kevin.Herron (there's also a corresponding Float.intBitsToFloat in the Java standard library)
