Configure a module with project resources
One other thing I am running into that someone else on this thread might, is that my resources don’t seem to be saving unless I close out the workspace tab first.
For example:
  1. I create a new resource
  2. I edit the resource
  3. I save the change, and take a look at the built file
  4. I then go back and close the open tab
  5. I save again, and go look at the file again
Any ideas what could cause this? I have tried overriding every method on the ResourceEditor class and can’t seem to find anything that fires when I hit save before the actual tab is closed.
Make sure to call ResourceEditor::commit() after making changes to your resource (probably with a document change listener on your text area, in your case).
This solved that problem! Hopefully all these answers help someone else trying to implement resources in a module. Might be a good update to add to Pauls Markdown example, I'll possibly make a fork if I can figure out enough Kotlin.
