Copying an Excel file to a table's dataset
Updrading Ignition to the latest (8.1.42, as of this writing) will update POI from 3.1.7 to 4.1.2.
When I originally posted this question, it took me awhile to find a solution that worked for me. I have only used it on one project the whole time. My solution was to copy each column in to a dataset from the excel sheet. I created a screen with a table that displays the dataset and a submit button. The submit button has a simple script to insert it into the database table. In the end it was a work around but it worked.
Screen Shot
Script
#imports
import system
#get data from dataset
data = event.source.parent.getComponent('Table').data
for insertrow in range(0,data.getRowCount()):
	query = "INSERT INTO PartsLocation(Location) VALUES(?)"
	args = [data.getValueAt(insertrow, 0)]
	system.db.runPrepUpdate(query, args)
I have upgraded Ignition and now it seems to work... Really strange :slight_smile:
How to link excel to dataset function filepath with the file upload component. Actually i am trying to pass the file path dynamically so user will be able to select the file path
You cannot supply a file path to an Upload component. That would be malware-ish behavior. The user must always control where the file comes from in their system.
nice job @JordanCClark , it works with the example files but i“ve a file with the next sequenece
test.xlsx (10.4 KB)
i try change to diferent formats but i can“t find the issue.
Your first column has differing datatypes. Excel doesn't give a wet slap what you format the cells for.
I have revamped the processing a bit. You can find it on my GitHub page.
Assuming you use the same package structure I show there, the functions of interest will be:
  • util.dataset.fromExcel()
  • util.dataset.fromExcelBytes() -- useful for using with perspective
  • util.dataset.processExceltoDataset()
system.dataset.toDataSet(headers,data) does not like different cellTypes in the same column when it converts to a Dataset. I don't care so much for numbers being numbers until after I'm handling aggregation within the dataset. I came across the same issue you had. Here is how I fixed it.
	            if cellType == 'NUMERIC':
	                if DateUtil.isCellDateFormatted(cell):
	                    value = cell.dateCellValue
	                else:
	                    value = str(cell.getNumericCellValue())
	            elif cellType == 'STRING':
	            	value = cell.getStringCellValue()
From the Documentation on XSSFCell(POI API Documentation)
XSSF API Documentation
"public java.lang.String getStringCellValue()
Get the value of the cell as a string
For numeric cells we throw an exception. For blank cells we return an empty string. For formulaCells that are not string Formulas, we throw an exception
Returns:
the value of the cell as a string"
the following is the data i’ve stored in excel -
and i get this error -
	def excelToDataSet(fileName, hasHeaders = False, sheetNum = 0, firstRow = None, lastRow = None, firstCol = None, lastCol = None):
		import org.apache.poi.ss.usermodel.WorkbookFactory as WorkbookFactory
		import org.apache.poi.ss.usermodel.DateUtil as DateUtil
		from java.io import FileInputStream
		from java.util import Date
		   Function to create a dataset from an Excel spreadsheet. It will try to automatically detect the boundaries of the data,
		   but helper parameters are available:
		   params:
		   		fileName   - The path to the Excel spreadsheet. (required)
		   		hasHeaders - If true, uses the first row of the spreadsheet as column names.
		   		sheetNum   - select the sheet to process. defaults to the first sheet.
		   		firstRow   - select first row to process.
		   		lastRow    - select last row to process.
		   		firstCol   - select first column to process
		   		lastCol    - select last column toprocess
		fileStream = FileInputStream(fileName)
		wb = WorkbookFactory.create(fileStream)
		sheet = wb.getSheetAt(sheetNum)
		if firstRow is None:
			firstRow = sheet.getFirstRowNum()
		if lastRow is None:
			lastRow = sheet.getLastRowNum()
		data = []
		for i in range(firstRow , lastRow + 1):
			row = sheet.getRow(i)
			print str(i).zfill(3), list(row)
			if i == firstRow:
				if firstCol is None:
					firstCol = row.getFirstCellNum()
				if lastCol is None:
					lastCol  = row.getLastCellNum()
				else:
					# if lastCol is specified add 1 to it.
					lastCol += 1
				if hasHeaders:
					headers = list(row)[firstCol:lastCol]
				else:
					headers = ['Col'+str(cNum) for cNum in range(firstCol, lastCol)]
			rowOut = []
			for j in range(firstCol, lastCol):
				if i == firstRow and hasHeaders:
					pass
				else:
					cell = row.getCell(j)
					system.perspective.print(i)
					system.perspective.print(j)
					system.perspective.print(cell)
					cellType = cell.getCellType().toString()
					system.perspective.print(cellType)
						else:
							value = cell.getNumericCellValue()
							if value == int(value):
								value = int(value)
					elif cellType == 'BOOLEAN':
						value = cell.getBooleanCellValue()
					elif cellType == 'BLANK':
						value = None
					elif cellType == 'FORMULA':
						formulatype=str(cell.getCachedFormulaResultType())
						if formulatype == 'NUMERIC':
							else:
									value = int(value)
						elif formulatype == 'STRING':
						elif formulatype == 'BOOLEAN':
						elif formulatype == 'BLANK':
							value = None
					else:
						value = None
					rowOut.append(value)
			if len(rowOut) > 0:
				data.append(rowOut)
		fileStream.close()
		return system.dataset.toDataSet(headers, data)
	fName = 'C:/Program Files/Inductive Automation/Ignition/data/excel/readExcel4.xlsx'
	ds1 = 	excelToDataSet(fName, True)
	self.getSibling("Table").props.data = ds1
Haven’t made any changes in the code except adding a few print statements to debug…
This happens after accessing the row 2 cells when an empty cell is encountered, not sure what to add/change in the code?
Sorry for the late reply. Spending a few days off for the Thanksgiving holiday.
Can you post the file that you’re having issues with?
Do you mean the Excel file?
test.xlsx (8.7 KB)
Edit: Ran the code for this on your github, i got the right output, with one caveat i.e., it works if none of the cells are Null.
what do i need to change for the code to work even for cells with nothing in them?
Error:
Seems to have trouble with single column datasets in Excel. I updated processExceltoDataset() to handle that.
Yess that worked! Thanks a lot! :smiley:
@JordanCClark
Had to make a few changes to processExcelToDataset() which included checking the limits of integers and long values. Please look out for comments with ā€˜Edit’.
def fromExcel(fileName, hasHeaders = False, sheetNum = 0, firstRow = None, lastRow = None, firstCol = None, lastCol = None, pyDataSet = False):
	print type(fileStream)
	return processExceltoDataset2(fileStream, hasHeaders, sheetNum, firstRow, lastRow, firstCol, lastCol, pyDataSet)
def processExceltoDataset(streamIn, hasHeaders = False, sheetNum = 0, firstRow = None, lastRow = None, firstCol = None, lastCol = None, pyDataSet = False):
	from com.inductiveautomation.ignition.common.util import DatasetBuilder
	from java.lang import String, Integer, Long, Boolean, Float, Double
	   params:
	   		streamIn   - The input stream of the Excel spreadsheet. (required)
	   		lastCol    - select last column to process
	   		pyDataSet  - return a PyDataSet
	wb = WorkbookFactory.create(streamIn)
	if lastRow is None:
	typeList = []
	data = []
		if i == firstRow:
			if lastCol is None:
			else:
				lastCol += 1
			colValues = [[] for idx in range(firstCol, lastCol)]
			colTypes = [None] * len(colValues)
			if hasHeaders:
			else:
		rowOut = []
		for idx, j in enumerate(range(firstCol, lastCol)):
				pass
			else:
				if row is None:
					value = None
				else:
					if cell is not None:
							cellType=str(cell.getCachedFormulaResultType())
						else:
								if colTypes[idx] is None:
									colTypes[idx] = Date
							else:
										intVal = int(value) # Check range for Integer # Start Edit 1
										if -2147483648 <= intVal <= 2147483647:
											colTypes[idx] = Integer
										elif -9223372036854775808 <= intVal <= 9223372036854775807:
											colTypes[idx] = Long
										else:
											colTypes[idx] = Double  # End Edit 1
									else:
								else:
									if colTypes[idx] == Integer:    # Edit 3
										if value != int(value):
										else:
											intVal = int(value)
											if not (-2147483648 <= intVal <= 2147483647):
									elif colTypes[idx] == Long:
											colTypes[idx] = Double   # End Edit 3
							if len(cell.getStringCellValue()) > 0:
								if colTypes[idx] is not String:
									colTypes[idx] = String
							else:
								value = None
								colTypes[idx] = Boolean
							value = None
						else:
							value = None
					else:
						value = None
				colValues[idx].append(value)
		if len(rowOut) > 0:
			data.append(rowOut)
	streamIn.close()
	# Normalize column data
	for i, colType in enumerate(colTypes):
		if colType is Integer:
			newCol = []
			for col in colValues[i]:
				if col is None:
					newCol.append(None)
				else:
					newCol.append(int(col))
			colValues[i] = newCol
		elif colType is Long:     # Start Edit 2
			newCol = []
				if col is None:
					newCol.append(None)
				else:
					newCol.append(long(col)) # Jython long
			colValues[i] = newCol    # End Edit 2
		elif colType is String:
			newCol = []
				if type(col) is float and col.is_integer():
					newCol.append(unicode(int(col)))
				else:
					newCol.append(unicode(col))
	if len(headers) == 1:
		data = [[value] for value in colValues[0]]
		if pyDataSet:
			return system.dataset.toPyDatSet(system.dataset.toDataSet(headers, data))
		else:
	builder = DatasetBuilder.newBuilder()
	builder.colNames(headers)
	builder.colTypes(colTypes)
	for row in zip(*colValues):
		builder.addRow(list(row))
	#dsOut = builder.build()
	if pyDataSet:
		#return system.dataset.toPyDataSet(system.dataset.toDataSet(headers, data))
		return system.dataset.toPyDataSet(builder.build())
	else:
		#return system.dataset.toDataSet(headers, data)
		return builder.build()
When i run this code against the attached excel, i get the following error -
com.inductiveautomation.ignition.common.script.JythonExecException
  File "<function:runAction>", line 5, in runAction
  File "<module:CSF.RAIL.CupConeManualImport.GetCupData>", line 5, in fromExcel
  File "<module:CSF.RAIL.CupConeManualImport.GetCupData>", line 174, in processExceltoDataset
java.lang.ClassCastException
java.lang.ClassCastException: java.lang.ClassCastException
	caused by org.python.core.PyException
	caused by ClassCastException
The following snippet is calling the processExcelToDataset within a button -
	filename = self.parent.custom.uploadedFileName
	lastRow = self.getSibling("QuantityNum").props.text
	filepath = 'C:\\Program Files\\Inductive Automation\\Ignition\\webserver\\webapps\\main\\CupConeBatchExcels\\CupBatchDetails\\'+filename
	ds1 = CSF.RAIL.CupConeManualImport.GetCupData.fromExcel(filepath,True,firstRow = 4,lastRow = 20,firstCol = 0,lastCol=1)
Copy of Cup_test.xlsx (10.6 KB)
Hey, why are you importing all those data types in the second function?
Took the code from this post, i believe it is supposed to recognize each cell’s type
It's to work with defining column types with DatasetBuilder()
Yeah, but imports belong in project library scripts, outside any function. No exceptions.
It was originally posted as a proof of concept, not a finished product. C'est la vie, my friend. :man_shrugging:
