Create momentary button using Vision standard button
Thanks. The frontend gateway does house the visuals with the backend housing the plc connections. The frontend is using remote tag providers to access the tags which live on the backend. I am doing my work on a VM and I am accessing the two gateways remotely through my VM. I start the vision client using the Tools-->Launch Project link through the project explorer.
A lot of moving parts so it is a little confusing.
End of the day I have it working correctly when I run the gateway script on the backend, getting the current date and time from the computer running the backend. On the button press I have the frontend gateway sending a message to the backend gateway project. The backend then sets the date and time using system.date.now() which is also coming from the backend gateway computer.
I get why people do a frontend backend setup but it does add some complications at times. Single gateway makes life much easier.
To be honest, I generally don't recommend it for Vision. It is almost a necessity for Perspective. Purely based on where the UI workload ends up.
