short explanation for everyone asking:
list.get()- I wanted an expression structure binding parameter to support named query (including 'json' Return Format option and input parameters)
- accomplished via runscript() and script transform on expression structure binding
- enabled parameters to be passed as json string or java.util.hashMap (no dict in expressions)
- scripting extensions module dataset to json arranges data differently
- wanted to return a default like named query does
binding
"type": "expr-struct",
"enabled": false,
"config": {
"struct": {
"consoles": "runScript(\n\t\u0027_system.db.runNamedQuery\u0027,\n\t0,\n\t\u0027Consoles/getConsoles\u0027\n)",
"userPrefs": "runScript(\n\t\u0027_system.db.runNamedQuery\u0027,\n\t0,\n\t\u0027Metadata/Get User Prefs\u0027, \n\tconcat(\"{\u0027Username\u0027:\", {session.props.auth.user.userName}, \"}\")\n)"
"waitOnAll": true
"transforms": [
"code": "\treturn {\n\t\t\u0027userPrefs\u0027:_system.dataset.pdsToJson(value.userPrefs).get(0,{}),\n\t\t\u0027consoles\u0027:_system.dataset.pdsToJson(value.consoles)\n\t}",
"type": "script"
_system
need to sublcass system.* instead of this hack
class dataset:
@staticmethod
class pdsToJson(list):
def __init__(self, pds):
self.pds = [{colName: value for colName, value in zip(pds.columnNames, row)} for row in pds] if pds else []
super(dataset.pdsToJson, self).__init__(self.pds)
def get(self, index, default=None):
if index < len(self.pds): return super(dataset.pdsToJson, self).__getitem__(index)
return default
class db:
@staticmethod
def runNamedQuery(path, parameters = None, tx = None, getKey = None):
import java.util.HashMap
assert type(path) == str or unicode
if type(parameters) == java.util.HashMap:
return system.db.runNamedQuery(path, dict(parameters), tx, getKey)
elif type(parameters) == str or unicode:
return system.db.runNamedQuery(path, system.util.jsonDecode(parameters), tx, getKey)
else: return system.db.runNamedQuery(path, parameters, tx, getKey)
PyJsonObjectAdapter.update()- was chaining script transforms (abandoned that per PTurmel's post on the matter)
basically I wanted one binding instead of multiple
critiques/alternatives welcome!
go easy on me
