You can define a logger in some code like:
logger = system.util.logger('what i want to show in the gateway logger column')
Then you can call that whenever with:
logger.info('message')
Just a way to setup the name of your logger at the top of your code without having to retype it for each message.
try:
system.db.runNamedQuery('query', param)
except Exception as e:
msg = str(e.getCause())
if 'Cannot insert duplicate key' in msg:
### code to popup a window with a message, or whatever else you want to do with it ###
@tyrel.parker ,
Ok, so I have defined the logger in the window open script like this…
logger = system.util.getLogger(“binderLogger”)
This way I can call if from any component in the window. (if I understand that correctly.)
I added this to my code…
try:
#Update binder_page table
system.db.runNamedQuery("page_name_update", {"new_page" :newPage, "topic_id" :topic_id})
msg = str(e.getClause())
logger.info('except javalang: {}'.format( msg)
if 'duplicate key value violates unique constraint' in msg:
logger.info( 'Page Name Already Exists.')
else:
pass
For some reason it does not like the if statement. says there is no alternative to the if. I must be missing something or syntax is not just right.
Any idea?
Thanks, Steven
So I found a missing bracket on the logger.info line.
it does not seem to affect anything.
Still pops up the same error message.
Not sure where to go now.
Thanks, Steven
My guess is that you need to tab in the pass or leave off the else all together.
else:
pass
I removed the else all together. I still get the same error message …
File "<event:propertyChange>", line 24, in <module>
Detail: Key (lower(page_name::text), topics_id)=(page 2, 9) already exists.
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: org.postgresql.util.PSQLException: ERROR: duplicate key value violates unique constraint "pagename_idx"
caused by GatewayException: org.postgresql.util.PSQLException: ERROR: duplicate key value violates unique constraint "pagename_idx"
caused by Exception: org.postgresql.util.PSQLException: ERROR: duplicate key value violates unique constraint "pagename_idx"
Ignition v8.0.16 (b2020082513)
Java: Azul Systems, Inc. 11.0.7
I guess it is not capturing the error.
Thanks, Steven
That error is from the gateway logs? Or when you click the button it gives you the error popup with that message?
@tyrel.parker it is in a popup after I press enter ( on property change).
Thanks, Steven
You can follow this method I outline in another post after you make the UNIQUE indexes
There are two ways to do this -
check for a duplicate manually with python before inserting, and if there’s a problem show the screen
Make UNIQUE INDEX definitions on your table in the database, and then just try/except inserting into it. Personally I like to leave data integrity to the database where appropriate, and ensuring UNIQUE-ness is one of those times in my opinion. I use this method for a MySQL DB and it looks like this in practice.
My personal solution would be to make your n…
tyrel.parker:
Did you figure this out?
I created a check prior to running the insert query so no error occurs. Made it nice and clean. I was checking for a blank anyway, so I just added to check for a duplicate as well.
Thanks for following up,
Steven
