Here's my QOL addition. Parameter presets. There are certain view usages that have a predetermined set of parameters, like a view to be used in a perspective table cell. I have a hot key that lets me pick from a set of predefined parameter sets and applies them to the view.
This sparked another idea, something to auto gen the columns list in a perspective table, taken from the columns in the data so you don't have to do this manually all the time.
The item that would be of most use to me in some of my projects would be to allow tag folders to be opened in the tag editor, to allow viewing and editing of custom properties. The can be written by script and read by scripts and bindings, but there is no convenient manual editing UI.
Clanker generated 'edit folder' addition to tag browser context menu. Only available on a single folder selection in the tag browser. I actually use custom properties on folders all the time so this might be my new favourite hahaha.
EDIT: Change out the system.util.getSystemFlags() function call for ApplicationScope.getGlobalScope() since the getSystemFlags moved to system.vision and breaks this in 8.3.
# QoL add-on: adds an "Edit Folder..." item to the Tag Browser right-click menu that
# opens the (folder-scoped) Tag Editor for the selected folder
from java.awt import Frame
_MENU_ITEM_KEY = "qolEditFolderItem"
_LISTENER_KEY = "qolEditFolderListener"
# Latest Tag Browser selection (list of tree nodes), kept fresh by the selection listener.
_selection = []
def _ctx_and_frame():
for f in Frame.getFrames():
try:
c = f.getContext()
if c is not None:
return c, f
except:
pass
return None, None
def _is_folder(node):
from com.inductiveautomation.ignition.designer.tags.tree.node import FolderNode
# Flip this to `return True` to show the item for tags/UDTs/folders alike.
return isinstance(node, FolderNode)
def _open_editor_for_selection():
if not _selection:
return
ctx, _ = _ctx_and_frame()
if ctx is None:
return
ctx.getTagEditor().editTag(_selection[0].getTagPath())
def install():
from java.awt.event import ActionListener
from javax.swing import JMenuItem, Action
from com.inductiveautomation.ignition.designer.sqltags.dialog import OnTagSelectedListener
ctx, frame = _ctx_and_frame()
if ctx is None:
return
rp = frame.getRootPane()
if rp.getClientProperty(_MENU_ITEM_KEY) is not None:
print "Edit Folder item already installed."
return
tb = ctx.getTagBrowser()
item = JMenuItem(u"Edit Folderβ¦")
try:
edit_icon = tb.getActions().getEdit().getValue(Action.SMALL_ICON)
if edit_icon is not None:
item.setIcon(edit_icon) # reuse Ignition's built-in edit icon
except:
pass
class _Open(ActionListener):
def actionPerformed(self, e):
item.addActionListener(_Open())
class _Sel(OnTagSelectedListener):
def tagSelectionChanged(self, tags):
global _selection
_selection = list(tags) if tags else []
# show the item only when a single folder is selected
item.setVisible(len(_selection) == 1 and _is_folder(_selection[0]))
listener = _Sel()
tb.addOnTagSelectedListener(listener)
tb.addTagPopupMenuComponent(item, 0) # 0 = top of the right-click menu
item.setVisible(False) # hidden until a folder is selected
rp.putClientProperty(_MENU_ITEM_KEY, item)
rp.putClientProperty(_LISTENER_KEY, listener)
print "Installed: 'Edit Folder' tag context-menu item (folders only)."
def uninstall():
# NOTE: the Tag Browser has no API to remove a popup item, so we can only HIDE it and
# stop the listener. The item object lingers in the popup until the Designer restarts.
if frame is None:
return
item = rp.getClientProperty(_MENU_ITEM_KEY)
if item is not None:
rp.putClientProperty(_MENU_ITEM_KEY, None)
listener = rp.getClientProperty(_LISTENER_KEY)
if listener is not None and ctx is not None:
ctx.getTagBrowser().removeOnTagSelectedListener(listener)
rp.putClientProperty(_LISTENER_KEY, None)
print "Uninstalled: 'Edit Folder' item hidden and listener removed (restart to fully clear)."
def _is_designer():
from com.inductiveautomation.ignition.common.model import ApplicationScope
return ApplicationScope.isDesigner(ApplicationScope.getGlobalScope())
if _is_designer():
install()
I'm a little behind in the Ignition updates, maybe this is already in there but...
The ability to make copies of alarms on a tag! When I have 32 alarms, one for each bit in an alarm word I hate having to type in the same alarm configuration over and over again when only the alarm name and bit number need to change.
With tags in general it's also good to note the "Copy as JSON" feature. You can copy an alarm configuration to a text editor like this and copy/paste the JSON into the tag database really easily.
It's also very useful if you're trying to make a lot of tags programmatically. You can use a script transform to convert tags from whatever format to Ignition tags for example.
This version is considerably more robust than the one I originally posted. I had a colleague intentionally try to poke holes in it, and that process led to several improvements.
Rather than disabling the OK button, the patch now uses a document listener to detect tag() expressions and display a warning icon. For enforcement, it intercepts the OK button's ActionListener and displays a lightweight popup if the user attempts to save an expression containing a tag() call.
I also added a selection listener to the binding type pane, so the warning automatically disappears when the user switches to a binding type other than an Expression Binding.
I take this back. I've been using this quite a bit now and the ability to filter for style classes that contain specific css prop names and/or values has been incredibly useful! For example, I can filter for style classes that:
set font-size
set "bold" font
set borders
set background colours
use specific colours or variable names
have animations
etc.
Which is invaluable if you don't know the style class names that you're looking for, but you know the css props that you need. Also the ability to view in the tooltip what declarations/css props the style class selector has is also very useful. So I would advocate for building this into a new UI design as well
this is slopy work at best and was done mostly by a clanker, but I was able to make a Gui wizard that auto pulls in column names and allows you to style the columns easier. you have to be selected onto the table you want when you run the command to open it.
appends the style from clipboard on top of existing styles
opens the table manager (if a table is selected)
the structure is as follows:
Dev.Clipboard:
import json
from java.awt import Toolkit
from java.awt.datatransfer import StringSelection, DataFlavor
def set_text(text):
try:
toolkit = Toolkit.getDefaultToolkit()
toolkit.getSystemClipboard().setContents(StringSelection(text), None)
except Exception as e:
print("ERROR: Failed to write to clipboard: %s" % e)
def get_dict():
try:
text = toolkit.getSystemClipboard().getData(DataFlavor.stringFlavor)
if not text: return None
payload = json.loads(text)
if isinstance(payload, dict):
return payload
print("ERROR: Clipboard is not a valid JSON Dictionary.")
return None
except ValueError:
print("ERROR: Clipboard content is not valid JSON.")
return None
print("ERROR: Failed to read clipboard: %s" % e)
return None
Dev.Context:
from java.awt import Window, Frame
def get_workspace_and_selection():
designer_window = None
for w in Window.getWindows():
if isinstance(w, Frame) and w.getTitle() and "Ignition Designer" in w.getTitle():
designer_window = w
break
if not designer_window:
return None, None, None
try:
ctx = designer_window.getContext()
p_mod = ctx.getModule("com.inductiveautomation.perspective")
ws = p_mod.getWorkspace()
editor = ws.getViewEditor() if hasattr(ws, 'getViewEditor') else ws.getSelectedEditor()
selection = editor.getSelection() if hasattr(editor, 'getSelection') else None
return ws, editor, selection
except Exception:
Dev.PropertyActions:
import json
import Dev.Clipboard as clip_mgr
import Dev.Context as ctx_mgr
try:
from com.inductiveautomation.perspective.common.api import PropertyType
except ImportError:
from com.inductiveautomation.perspective.common.config import PropertyType
class CopyAction(ActionListener):
def __init__(self, target_prop_type):
self.target_prop_type = target_prop_type
def actionPerformed(self, event):
_, _, selection = ctx_mgr.get_workspace_and_selection()
if not selection or selection.isEmpty(): return
comp_details = selection.getComponentDetails()
if not comp_details or comp_details.isEmpty(): return
comp = comp_details.get(0)
prop_node = getattr(comp, self.target_prop_type, None)
if prop_node is None: return
raw = prop_node() if callable(prop_node) else prop_node
try:
json_str = unicode(raw.toString() if hasattr(raw, "toString") else str(raw))
parsed = json.loads(json_str)
clip_mgr.set_text(json.dumps(parsed, indent=4))
print("SUCCESS: Copied '%s' properties to clipboard!" % self.target_prop_type)
print("ERROR: Failed to copy properties: %s" % e)
class PasteAction(ActionListener):
payload = clip_mgr.get_dict()
if not payload:
print("INFO: Clipboard is empty or does not contain a valid dictionary.")
return
print("INFO: No component selected.")
return
p_type = PropertyType.custom if self.target_prop_type == "custom" else PropertyType.params
try:
json_payload = json.dumps(payload)
selection.write(p_type, "", json_payload)
print("SUCCESS: Natively injected into '%s'!" % self.target_prop_type)
print("ERROR: Failed to paste properties: %s" % e)
class AppendStylesAction(ActionListener):
if not payload: return
# Smart unwrap if the user copied the parent {"style": {...}} object
if "style" in payload and isinstance(payload["style"], dict):
payload = payload["style"]
existing_classes = ""
try:
comp = selection.getComponentDetails().get(0)
raw_props = comp.props() if callable(comp.props) else comp.props
props_dict = json.loads(unicode(raw_props.toString() if hasattr(raw_props, "toString") else str(raw_props)))
c = props_dict.get("style", {}).get("classes", "")
if isinstance(c, basestring):
existing_classes = c
except Exception: pass
# Properties that require string units (like 'px') in CSS
pixel_properties = ["fontSize", "width", "height", "padding", "margin",
"borderRadius", "borderWidth", "top", "bottom", "left", "right"]
try:
for key, value in payload.items():
# π SMART TYPE CASTER: Automatically convert numeric sizes to px strings!
if key in pixel_properties and isinstance(value, (int, float)):
value = "%dpx" % int(value)
# Smart CSS Class merging
if key == "classes" and existing_classes and isinstance(value, basestring):
new_classes = existing_classes
for c in value.split():
if c not in new_classes.split():
new_classes += " " + c
value = new_classes.strip()
# Write natively to the style dictionary path
selection.write(PropertyType.props, "style." + key, json.dumps(value))
print("SUCCESS: Styles successfully appended!")
print("ERROR: Failed to append styles: %s" % e)
Dev.TableWizard:
import json
import copy
import re
from java.awt import BorderLayout, FlowLayout, GridLayout, Dimension, Color, Window, Frame
from java.awt.event import ActionListener, KeyAdapter
from javax.swing import (JPanel, JButton, JLabel, BorderFactory, JDialog, JTextField,
JCheckBox, JComboBox, JList, JScrollPane, ListSelectionModel, JColorChooser)
from javax.swing.event import ListSelectionListener
try:
except ImportError:
class LaunchWizardAction(ActionListener):
launch_table_wizard()
def launch_table_wizard():
DEFAULT_COLUMN_TEMPLATE = {
"field": "", "visible": True, "editable": False, "render": "auto",
"justify": "auto", "align": "center", "resizable": True, "sortable": True,
"width": "", "strictWidth": False,
"style": { "classes": "" },
"header": { "title": "", "justify": "left", "align": "center", "style": { "classes": "" } },
def _format_header_title(key):
if not key: return ""
formatted = re.sub(r'([a-z0-9])([A-Z])', r'\1 \2', key).replace('_', ' ').replace('-', ' ')
return " ".join([word.capitalize() for word in formatted.split() if word])
def _hex_to_color(hex_str, default_color):
try:
if hex_str.startswith("#") and len(hex_str) == 7: return Color.decode(hex_str)
return default_color
class _ColumnWizardDialog:
def __init__(self, parent_window, keys, existing_col_map):
self.keys = keys
self.existing_col_map = existing_col_map
self.accepted = False
self.configs = {}
for k in self.keys:
if k in self.existing_col_map:
c = self.existing_col_map[k]
h_style = c.get("header", {}).get("style", {})
c_style = c.get("style", {})
self.configs[k] = {
"title": c.get("header", {}).get("title", _format_header_title(k)),
"header_align": c.get("header", {}).get("align", "center"),
"content_align": c.get("align", "left"),
"sortable": c.get("sortable", True),
"resizable": c.get("resizable", True),
"width": c.get("width", ""),
"strict_width": c.get("strictWidth", False),
"font_size": c_style.get("fontSize", "13px"),
"header_bg": h_style.get("backgroundColor", "#1A202C"),
"header_text": h_style.get("color", "#FFFFFF"),
"cell_bg": c_style.get("backgroundColor", "#F4F5F7"),
"cell_text": c_style.get("color", "#333333"),
"header_extra": json.dumps({key: val for key, val in h_style.items() if key not in ["backgroundColor", "color"]}),
"cell_extra": json.dumps({key: val for key, val in c_style.items() if key not in ["backgroundColor", "color", "fontSize"]})
else:
self.configs[k] = {
"title": _format_header_title(k), "header_align": "center", "content_align": "left",
"sortable": True, "resizable": True, "width": "", "strict_width": False, "font_size": "13px",
"header_bg": "#1A202C", "header_text": "#FFFFFF", "cell_bg": "#F4F5F7", "cell_text": "#333333",
"header_extra": '{"fontWeight": "bold"}', "cell_extra": '{"fontWeight": "bold", "border": "1px solid #E5E7EB", "padding": "8px"}'
self.global_config = copy.deepcopy(self.configs[self.keys[0]] if self.keys else {})
self.last_sel = "-- ALL COLUMNS --"
self.dialog = JDialog(parent_window, "Perspective Column Editor", True)
self.dialog.setSize(650, 700)
self.dialog.setLayout(BorderLayout(10, 10))
self.dialog.setLocationRelativeTo(parent_window)
list_panel = JPanel(BorderLayout())
list_panel.setBorder(BorderFactory.createTitledBorder("Columns"))
list_panel.setPreferredSize(Dimension(200, 0))
self.col_list = JList(["-- ALL COLUMNS --"] + self.keys)
self.col_list.setSelectionMode(ListSelectionModel.SINGLE_SELECTION)
class _ListProxy(ListSelectionListener):
def __init__(self, outer): self.outer = outer
def valueChanged(self, e):
if not e.getValueIsAdjusting():
ns = self.outer.col_list.getSelectedValue()
if ns != self.outer.last_sel:
self.outer._save_form_state()
self.outer._load_form_state(ns)
self.outer.last_sel = ns
self.col_list.addListSelectionListener(_ListProxy(self))
list_panel.add(JScrollPane(self.col_list), BorderLayout.CENTER)
self.dialog.add(list_panel, BorderLayout.WEST)
settings_panel = JPanel(GridLayout(15, 2, 6, 6))
settings_panel.setBorder(BorderFactory.createTitledBorder("Settings"))
settings_panel.add(JLabel(" Header Title:"))
self.txt_title = JTextField("<Multiple Values>")
self.txt_title.setEnabled(False)
settings_panel.add(self.txt_title)
settings_panel.add(JLabel(" Header Align:"))
self.cb_h_align = JComboBox(["left", "center", "right"])
settings_panel.add(self.cb_h_align)
settings_panel.add(JLabel(" Content Align:"))
self.cb_c_align = JComboBox(["auto", "left", "center", "right"])
settings_panel.add(self.cb_c_align)
self.chk_sort = JCheckBox("Sortable", True)
settings_panel.add(self.chk_sort)
self.chk_res = JCheckBox("Resizable", True)
settings_panel.add(self.chk_res)
settings_panel.add(JLabel(" Width (e.g., '150px' or ''):"))
self.txt_width = JTextField("")
settings_panel.add(self.txt_width)
self.chk_sw = JCheckBox("Strict Width", False)
settings_panel.add(self.chk_sw)
settings_panel.add(JLabel(""))
settings_panel.add(JLabel(" Cell Font Size:"))
self.txt_font = JTextField("13px")
settings_panel.add(self.txt_font)
def make_color_action(textfield):
class ActionProxy(ActionListener):
chooser = JColorChooser(_hex_to_color(textfield.getText().strip(), Color.WHITE))
class OkProxy(ActionListener):
def actionPerformed(self, ev):
c = chooser.getColor()
if c:
textfield.setText("#%02X%02X%02X" % (c.getRed(), c.getGreen(), c.getBlue()))
dg = JColorChooser.createDialog(self.outer.dialog, "Pick", True, chooser, OkProxy(), None)
dg.setVisible(True)
ap = ActionProxy(); ap.outer = self
return ap
for lbl, txt_ref in [(" Header BG Color:", "txt_h_bg"), (" Header Text Color:", "txt_h_text"),
(" Cell BG Color:", "txt_c_bg"), (" Cell Text Color:", "txt_c_text")]:
settings_panel.add(JLabel(lbl))
p = JPanel(BorderLayout(5, 0))
tf = JTextField("#000000")
setattr(self, txt_ref, tf)
p.add(tf, BorderLayout.CENTER)
p.add(JButton("π¨", actionPerformed=make_color_action(tf)), BorderLayout.EAST)
settings_panel.add(p)
settings_panel.add(JLabel(" Extra Header Style (JSON):"))
self.txt_h_extra = JTextField("{}")
settings_panel.add(self.txt_h_extra)
settings_panel.add(JLabel(" Extra Cell Style (JSON):"))
self.txt_c_extra = JTextField("{}")
settings_panel.add(self.txt_c_extra)
self.dialog.add(settings_panel, BorderLayout.CENTER)
btn_panel = JPanel(FlowLayout(FlowLayout.RIGHT))
class BtnProxy(ActionListener):
def __init__(self, fn): self.fn = fn
def actionPerformed(self, e): self.fn(e)
def on_inject(e):
self._save_form_state()
self.accepted = True
self.dialog.dispose()
btn_panel.add(JButton("Cancel", actionPerformed=BtnProxy(lambda e: self.dialog.dispose())))
btn_panel.add(JButton("Apply & Inject Columns", actionPerformed=BtnProxy(on_inject)))
self.dialog.add(btn_panel, BorderLayout.SOUTH)
self.col_list.setSelectedIndex(0)
def _save_form_state(self):
d = {
"header_align": self.cb_h_align.getSelectedItem(), "content_align": self.cb_c_align.getSelectedItem(),
"sortable": self.chk_sort.isSelected(), "resizable": self.chk_res.isSelected(),
"width": self.txt_width.getText().strip(), "strict_width": self.chk_sw.isSelected(),
"font_size": self.txt_font.getText().strip(), "header_bg": self.txt_h_bg.getText().strip(),
"header_text": self.txt_h_text.getText().strip(), "cell_bg": self.txt_c_bg.getText().strip(),
"cell_text": self.txt_c_text.getText().strip(), "header_extra": self.txt_h_extra.getText().strip(),
"cell_extra": self.txt_c_extra.getText().strip()
if self.last_sel == "-- ALL COLUMNS --":
self.global_config = d
for k in self.keys: self.configs[k].update(d)
else:
d["title"] = self.txt_title.getText()
self.configs[self.last_sel].update(d)
def _load_form_state(self, sel):
c = self.global_config if sel == "-- ALL COLUMNS --" else self.configs[sel]
self.txt_title.setText("<Multiple Values>" if sel == "-- ALL COLUMNS --" else c.get("title", ""))
self.txt_title.setEnabled(sel != "-- ALL COLUMNS --")
self.cb_h_align.setSelectedItem(c.get("header_align"))
self.cb_c_align.setSelectedItem(c.get("content_align"))
self.chk_sort.setSelected(c.get("sortable", True))
self.chk_res.setSelected(c.get("resizable", True))
self.txt_width.setText(c.get("width", ""))
self.chk_sw.setSelected(c.get("strict_width", False))
self.txt_font.setText(c.get("font_size", "13px"))
self.txt_h_bg.setText(c.get("header_bg", ""))
self.txt_h_text.setText(c.get("header_text", ""))
self.txt_c_bg.setText(c.get("cell_bg", ""))
self.txt_c_text.setText(c.get("cell_text", ""))
self.txt_h_extra.setText(c.get("header_extra", "{}"))
self.txt_c_extra.setText(c.get("cell_extra", "{}"))
def show(self):
self.dialog.setVisible(True)
return self.configs if self.accepted else None
# --- EXECUTE WIZARD ---
ws, editor, selection = ctx_mgr.get_workspace_and_selection()
print("ERROR: No Table selected.")
return
try:
except Exception:
return
props_data = props_dict.get("data", {})
existing_cols = props_dict.get("columns", [])
existing_col_map = {str(c["field"]): c for c in existing_cols if isinstance(c, dict) and "field" in c}
column_keys = set(existing_col_map.keys())
if isinstance(props_data, list) and len(props_data) > 0 and isinstance(props_data[0], dict):
column_keys.update([str(k) for k in props_data[0].keys() if not str(k).startswith("$")])
elif isinstance(props_data, dict):
if "$columns" in props_data:
column_keys.update([str(c.get("name", "")) for c in props_data["$columns"]])
elif "columns" in props_data:
column_keys.update([str(c.get("name", "")) for c in props_data["columns"]])
elif "$a" in props_data and isinstance(props_data["$a"], list) and len(props_data["$a"]) > 0:
column_keys.update([str(k) for k in props_data["$a"][0].keys() if k != "$"])
elif "type" not in props_data:
column_keys.update([str(k) for k in props_data.keys() if not str(k).startswith("$")])
sorted_keys = sorted(list(column_keys))
designer_window = [w for w in Window.getWindows() if isinstance(w, Frame) and "Ignition Designer" in w.getTitle()][0]
# π SMART FALLBACK: Allow JSON string pasting!
if not sorted_keys:
input_str = JOptionPane.showInputDialog(
designer_window,
"No columns detected (Data might be bound).\n\nYou can type comma-separated names OR paste a JSON sample row/array here:",
"Data Schema Entry",
JOptionPane.QUESTION_MESSAGE
if not input_str or not input_str.strip():
print("INFO: User cancelled manual column entry.")
return
input_str = input_str.strip()
try:
# Try to parse the pasted text as JSON
pasted_json = json.loads(input_str)
if isinstance(pasted_json, list) and len(pasted_json) > 0 and isinstance(pasted_json[0], dict):
sorted_keys = [str(k) for k in pasted_json[0].keys() if not str(k).startswith("$")]
elif isinstance(pasted_json, dict):
sorted_keys = [str(k) for k in pasted_json.keys() if not str(k).startswith("$")]
except Exception:
# If it's not valid JSON, treat it as comma-separated values
sorted_keys = [k.strip() for k in input_str.split(",") if k.strip()]
if not sorted_keys:
print("ERROR: Could not parse any keys from your input.")
return
wizard = _ColumnWizardDialog(designer_window, sorted_keys, existing_col_map)
final_configs = wizard.show()
if not final_configs: return
new_columns = []
for key in sorted_keys:
c_state = final_configs[key]
col = existing_col_map.get(key, copy.deepcopy(DEFAULT_COLUMN_TEMPLATE))
col.update({"field": key, "align": c_state["content_align"], "sortable": c_state["sortable"],
"resizable": c_state["resizable"], "width": c_state["width"], "strictWidth": c_state["strict_width"]})
if "header" not in col: col["header"] = {}
col["header"].update({"title": c_state["title"], "align": c_state["header_align"]})
header_style = {"backgroundColor": c_state["header_bg"], "color": c_state["header_text"]}
cell_style = {"backgroundColor": c_state["cell_bg"], "color": c_state["cell_text"], "fontSize": c_state["font_size"]}
try:
if c_state["header_extra"] not in ["{}", ""]: header_style.update(json.loads(c_state["header_extra"]))
if c_state["cell_extra"] not in ["{}", ""]: cell_style.update(json.loads(c_state["cell_extra"]))
col["header"]["style"] = header_style
col["style"] = cell_style
new_columns.append(col)
selection.write(PropertyType.props, "columns", json.dumps(new_columns))
print("SUCCESS: Full column schema injected!")
Dev.UtilityToolbar:
from java.awt import FlowLayout, Window, Frame, Color, Insets
from javax.swing import JPanel, JButton, JLabel, BorderFactory
import Dev.PropertyActions as actions
import Dev.TableWizard as wizard
# Unique name to identify our injected JPanel container
MARKER_NAME = "dev_perspective_utility_panel"
def inject():
"""Builds and attaches the custom utility toolbar to the Property Editor's header bar."""
# Run an uninstall first to ensure we never stack duplicate panels
uninstall()
designer_window = w
break
return
context = designer_window.getContext()
propertyEditor = context.dockingManager.getFrame("PerspectivePropEditor")
if propertyEditor:
# Create the custom Swing panel and name it so we can find it during uninstall
utilityPanel = JPanel(FlowLayout(FlowLayout.LEFT, 3, 1))
utilityPanel.setName(MARKER_NAME)
utilityPanel.setBorder(BorderFactory.createMatteBorder(0, 0, 1, 0, Color.LIGHT_GRAY))
utilityPanel.add(JLabel("Utils: "))
buttons = [
("Copy Custom", actions.CopyAction("custom"), None),
("Paste Custom", actions.PasteAction("custom"), None),
("Copy Params", actions.CopyAction("params"), None),
("Paste Params", actions.PasteAction("params"), None),
("Append Styles", actions.AppendStylesAction(), Color(0, 100, 0)),
("Table Wizard", wizard.LaunchWizardAction(), Color(0, 70, 140))
for text, action, color in buttons:
btn = JButton(text)
btn.setMargin(Insets(1, 4, 1, 4))
btn.addActionListener(action)
if color: btn.setForeground(color)
utilityPanel.add(btn)
# Bind the panel persistently to JIDE's Title Bar component slot
propertyEditor.setTitleBarComponent(utilityPanel)
# Redraw the frame
propertyEditor.revalidate()
propertyEditor.repaint()
print("SUCCESS: Modular Toolbar bound to Property Editor!")
def uninstall():
"""Removes our custom panel and restores the Property Editor's title bar back to standard."""
try:
designer_window = w
break
return False
if propertyEditor:
current_component = propertyEditor.getTitleBarComponent()
# Check if our custom named panel is currently occupying the title bar
if current_component and current_component.getName() == MARKER_NAME:
# Wiping the title bar component slot completely restores JIDE's default layout
propertyEditor.setTitleBarComponent(None)
# Force immediate re-layout calculation and redrawing
print("SUCCESS: Modular Toolbar cleanly uninstalled from Property Editor.")
return True
return False
print("ERROR: Failed to uninstall Property Editor toolbar: %s" % e)
return False
then just run Dev.UtilityToolbar.inject() or have it run in a vision client tag on change script as explained in this thread.
Donating this to the folks here, a [1] less cursed way to run, basically, designer local modules:
It'll run some files saved in your .ignition cache on various lifecycle hooks if you've opted in to 'attaching' it via your designer launcher configuration. That would allow you to save one set of scripts in your local user profile and load it onto any number of (8.3) connected designers, without making any changes in the project.
You can edit these files with your resident clanker, or directly inside the designer in a popup frame you invoke from the Tools menu.
No future maintenance guarantees are made, this is not an official IA product, use at your own risk, etc, etc.
