[IGN-15796] Designer tag browser panel scroll bar disappears
When expanding tags past the view height of the tag browser, the scroll bar appears. However, when you deselect all options (value, data type) in the column chooser, the scroll bar disappears even if the tag list is longer than the height of the panel.
Not sure if this is intended functionality, but it is a small annoyance. Sometimes there are instances where deselecting the columns to just get a decluttered tag list is helpful. Am I missing something?
I imagine it is because of the way the swing component detects values. Since you are not displaying any information you would not need to scroll anyways :man_shrugging:
FWIW I do see this behavior as well.
I wonder if this bug is in the list to fix. I can’t imagine this is intended behavior?
Our QA has reviewed this and made a ticket.
