DNP3 Binary Output Operation Via Tag
Thanks Kevin, named params doesn't make a difference - I'll see if I can get an instance of wireshark up on site
It seems that I also experience similar concerns discussed here with same device.
Direct Tag Write (system.tag.writeBlocking) does not work.
I can only work with system.dnp3.directoperatebinary and system.dnp3.selectoperatebinary
If doing pulse command, the pulse setting is not written to RTAC.
And can you also provide background info when system.dnp3.directoperatebinary and system.dnp3.selectoperatebinary returns -1. What does -1 mean? I assume general fail but is there a way to specifically determine issue?
Thanks!
