Does a Tag Timestamp reset if overwritten by same value?
Dependent on the type of tag.
In my quick testing, the timestamp was updated for a memory tag, but was not for an OPC tag using IA's OPC connected through the Allen-Bradley Ethernet IP Driver.
I believe that this behavior is an implementation detail of the driver and server, so for instance you may get differing results if you are using IA's OPC server in comparison to using an on-device opc server, or Kepware.
