LOL. I do that so that I can easily recognize what type of component it is. But, I use underscore like so: lbl_Title
This is a great post with a lot of helpful tips. Any level of experience could learn something from this post. I wanted to share this thread with newer developers but wanted it a bit better organized. Thanks to the help of my make-believe assistant, I was able to do this relatively easy!
Wanted to share the output here too.
I take no credit for this knowledge.
1. Naming, Folders & Structure
Don’t be scared of making folders; navigation is key—better folders than a mess of files.
credit: @danielps1818 -
Give inputs names that match their purpose; container names should describe contents (Top/Bottom/Left/Right, Header/Footer) to ease view-tree navigation.
credit: @Ryan_Deardorff -
Fixing container/component names can break views that don’t use #13.
credit: @pturmel -
Aim for Jython-friendly naming: avoid spaces and be careful with non-alphanumeric characters.
credit: @msteele -
Build tag paths that are concise, human-readable, and meaningful.
credit: @msteele -
Folders can have custom properties (not visible in Designer) and can be written via
system.tag.writeBlocking()or tooling.
credit: @msteele -
Document your naming/folder conventions so others (and future you) can follow them; consistency matters more than perfection.
credit: @Brandon_Peterson -
“FlexContainer_0”… if you follow that pattern, remember to increment.
credit: @msteele
2. Scripting Architecture & Reuse
Put event logic in the scripting library; event/tag/property handlers should be one-liners that call library functions.
credit: @bkarabinchak.psi -
Reasons: version-controllable/diff-able; easier to test via script console; decorators (e.g.,
@timeAndLog) add cross-cutting features without editing every event; reusable; avoids old scoping issues.
Prefer a base parent project for reusable code over copy-and-paste.
Reuse aggressively (imports/exports, reusable classes); think about the next project—but note that “global” variables and heavy abstraction can introduce errors.
Beware over-abstraction: it’s OK to duplicate views (e.g., create vs. edit) instead of forcing one to fit multiple roles; simpler and safer to change later.
credit: @pascal.fragnoud
Example decorator:
@timeAndLog def foo(*args, **kwargs): passcredit: @bkarabinchak.psi
3. UI & Perspective (Bindings, Patterns, Animations)
Don’t push from tag scripts to UI; bind tags to UI properties to pull data, and place change-monitoring actions in the UI where needed.
credit: @pturmel -
Scripts are resource-heavy—use bindings instead (preferably without script transforms).
credit: @pturmel -
Simple property bindings are fastest.
credit: @pturmel -
Tag and named-query bindings are asynchronous; reference them with simple property bindings instead of curly-brace tag refs or scripted queries.
credit: @pturmel -
Expression bindings are faster than scripts; if you must script in a binding,
runScript()in an expression binding is faster than a script transform.
credit: @pturmel -
Avoid the
tag()expression function “like the plague.”
credit: @pturmel -
Don’t use scripts for Perspective animations—use CSS/style animations.
credit: @victordcq -
If something seems “impossible” in Perspective, ask on the forum; CSS/JS injection workarounds may exist.
credit: @victordcq
4. Scope (Gateway vs Client)
Schedule/house server-side tasks (e.g., 5 AM resets of DB tables/tags) in the gateway scope—not client—so they run even if clients are closed and to avoid N× duplication across many clients.
Inverse: don’t use gateway tags to track client UI state; use client tags/session props.
5. Database & Queries
- Get DB design right: correct data types (don’t store dates as strings); use named or prepared queries; use transactions; ensure uniqueness via a proper PK or UNIQUE index.
6. Tags, UDTs & Tooling
Spreadsheet Import Tool can create implied folders while writing tags and UDT instances—helps counter the “UDTs are inflexible” critique.
credit: @msteele (plugging @pturmel’s tool) -
Custom properties are powerful (e.g., store view paths/tag paths as strings).
credit: @msteele -
Explore var-map functions in the Integration Toolkit module for advanced patterns.
credit: @msteele
7. Process & Community
Document conventions so you can iterate and improve across projects.
If people say it’s impossible, tag experts for workarounds.
credit: @victordcq
I don't find a wall of mostly bold-face text to be "better organized". Not to mention that you omitted all of the reference links. LLM output is generally not welcome here on this forum. See the FAQ for details.
Do you have suggestions on how it could be organized for newer users? For instance if they wanted to improve their UI.
Maybe not the end all best way to bucket the tips but it was quick way to get a first iteration.
You mention a couple of mine, but not the one I feel strongest about (#13). It can save so much time and hassle when rearranging components. So much so that I feel like Ignition should never have allowed custom properties on anything but the view, and made each component’s props only visible to itself.
Yes, read the whole topic, follow the links. The topic itself is a bunch of summaries. Re-summarizing is lossy.
Newbies using LLMs with Ignition is a good way to waste time and get in a bind.
Agreed on having a newbie avoid LLMs all day. This came to mind after talking to someone about how data flows through a project, and wanted to give them community driven tips. They’re some in here but in between heaps of other good tips.
Using this thread as the dataset for the LLM to paraphrase from I felt a bit better about myself. I also don’t like how it has the reply links omitted not allowing one to easily see more context. Was interesting to have this as a use case and see the result.
Most of this has been covered already other’s posts but I thought I’d write up some mistakes that happened on the first project I inherited and had to fix up.
- Complex bindings - passing objects (key1) to embedded views rather than simply values. At first it seemed fine until the project grew and bandaid fixes would add more sub-tags to key1 and then perspective started to not always display the correct objects. A lot of rework was done to only pass simple values like tagpath into the object and then move any additional info into the UDT itself.
- SQL - We had some niche requirements that needed custom database tables made to store certain things we couldn’t save into tags. During early development it was never considered that clients on gatewayA won’t have a network path to the database connected to gatewayB for cybersecurity reasons. Took a fair bit of re-work to break up how things were done, moving some into tags and some into remotely executing named queries with message handlers. In hindsight I would’ve pushed back on the project requirements to simply just not agree to do certain things.
- Too many embedded views, not necessarily related to point 1 but rather just making every little widget it’s own view but often times some of those widgets were only ever used in one place. This meant for maintenance you had to constantly jump around the project to find where you could make a change. Use embedded views when it makes sense or they’re recycled but don’t needlessly use them and create clutter.
- Be mindful of choices when laying out tag / folder structures. Objects like tagbrowser or powerchart use those structures so it’s important to make things clear and consistent from the very beginning as operations will see it down the road.
- Make better use of session.custom properties and not always rely solely on view.custom.
Don’t do what I did in one project and name your views too generically. For example:
Specific Thing > Views > Main View
Other Specific Thing > Views > Main View
When you have a bunch of tabs open and several are named “main” or “template” or something else really generic, it’s a huge pain for your workflow.
I don’t know if this was mentioned or not, but be very careful with Script transforms on bindings, especially in template views. If that template is on a flex repeater and iterated a bunch of times, every iteration is going to run that script transform, and then multiply that by every session of that project that’s open, and you could have literally hundreds of scripts per second running before you know it. I’ve seen it take down gateways before.
Ideally, scripts should be run at very slow intervals, or on-demand only. If there is any way you can possibly avoid a script transform on a binding, do it. If you can’t avoid it, try to put the script in your project library and call it with the runScript() expression instead. You should only ever have a script transform if there was absolutely no other way to accomplish what you wanted to accomplish. And if you think that’s the case, it is well worth the time to research and make sure it is. Not every nail needs a python-shaped hammer. There is usually a better way to do it.
They should have used Claude ![]()
SQL is an awesome language if you really dive deep. And it's fast.
But yeah, certain things just shouldn't be done in SQL.. even if they can be.
If the data source is large (I.E. A large site with a lot of tags, alarmed and historized from a lot of PLC’s), is it not reasonable to offload fuctions to the database? I’m referring to pgFunctions in PostgreSQL in this case. I found by doing this, it massively improved the response time in my Perspective views. How do you suggest handling this situation?
If it got to the point where running a series of SQL statements in ignition was going considerably slower running it inside a function all in the databse, then it makes sense to switch.
I certainly would not start there and assume that though. I would program all my SQL statements in a single transaction in ignition and only if I run into a bottleneck seek to offload it to the database entirely in a function/stored procedure and see if it improves or to see if caching somewhere could help.
What were your queries like before that were taking so long? Since you mention its for a view I have to imagine its mostly select queries. I do find it odd that running them inside a function would provide a substantial boost over running through ignition. I am curious what your specific queries are that cause such a situation and what perfomance was in ignition vs a pgFunction.
Worth noting too if these queries you are running involve UPDATE/INSERT/DELETE you 100% should be wrapping them in a transaction in Ignition for both atomocity but also it improves performance for basically all flavors of db. If that’s the case I wonder if in ignition you were not wrapping them in a transaction but in your pgFunction you are. Quick search does tell me pgfunctions do automatically execute inside of one transaction so this may be something.
Could anyone give any example on what he means? We don't usually use session.custom. Would be nice to learn something new.
These are custom properties defined at the session level. You can use them when you have values that need to be shared across multiple views in Perspective.
For example, if several views need to follow the same aspect ratio, you can define it once under session.custom and then reference it wherever needed in those views.
Sometimes you want to have different user configurable settings on a view and make them persist across the entire session so that when the user navigates away from that page and back again, they don't have to redo everything (e.g. an Ad Hoc Trending page).
Something to keep in mind with session.custom is that if you ever plan on the operator being able to open the same view on multiple screens you can't use session.custom for screen indirection.
Sure, one example is I used session properties to mirror a power chart so that if the user changes to a different view they don't lose their graph. Then I also added a context menu on any live points on the various screens so the operator can right click and add to chart. That way they can build charts without having to use the tag browser.
Worth understanding though there is a known bug that sometimes designer loses your session properties and if you save they disappear... so you have to be mindful of that bug.
That's why I use database persistence rather than session properties. That doesn't disappear when the user logs out, or logs in from a different device.
