Dragging rows in Perspective Table
Hey Kenny, when does this error occur?
I am trying to get this to work when using the table as a parameterized embedded view with multiple versions embedded on a parent view. I have this working with the table, but when I go to my parent view that has 3x of these tables embedded, the drag and drop only works on one of the three tables (different table each time). If, for instance, table 1 on the parent view is working, if I drag and drop in table 2 or 3, it changes the order on table 1.
Any idea how I can get this to work independently on all three embedded tables in my parent view?
This script selects all the tables in the view, are you putting the markdown inside each embeded view?
provide copy of the views so i can take a look, this post is a bit old for me to remember what i all did , there are also multiple versious running around the forum so yeah...
Sorry for reviving an old thread!
There is one view with the table and markdown on it (dragTable view). That table view gets embedded three times on a parent view. The parent view passes in a parameter to the table view to make tell the table what data source to pull data from.
When accessing the parent view via it's URL, when you try to drag and drop from one of the three tables, the view 'randomly' selects which one of the three tables actually moves data. For instance , if you drag row 1 in table 1 to the bottom row, instead of the data in table 1 moving, row 1 in table 3 moves. The affected table may be different each time you reload the page.
drag_table_test.zip (78.7 KB)
Here in an example of the views and how they work. Note that in this example, the data is the same in the tables, the only parameter that the parent view is passing in is the table name. This is showing the same functionality though, from a drag and drop perspective.
No worries, still happy to help, just needed to see what you were working with :stuck_out_tongue:
This seems like an older version of the code without mutation observer. Meaning that if you data updates, it might loose its functionality (especially when updating from an empty table to a full one.) Look a bit further in this topic to read more about this if this cause can happen to you.
Anyways to make this functional with multilpe sub views on the screen, you can add this.
This viewSelector will make sure it will only select things inside the view (note this does include sub views!)
If you are gonna use an updated version of this code, be sure to add the viewSelector + to every querySelector
		const viewPath = this.closest('[data-component-path]').getAttributeNode('data-component-path').value;
		const viewSelector = 'div[data-component-path^="'+viewPath.substr(0, viewPath.lastIndexOf(':'))+'"] ';
		document.querySelectorAll(viewSelector + '.tr-group.ia_table__rowGroup')
victordcq, is there a way to access session custom props from within the injected JS? Not allowed to mention so hopefully you're watching the post. Wanted to generalize this logic so we can use it on multiple views. So far I have this:
var rowDroppedData = window.__client.page.sessionCustom.root.value.value.get('rowDroppedData').value.value;
rowDroppedData.get('draggedId').value.value = draggedId;
rowDroppedData.get('droppedId').value.value = droppedId;
rowDroppedData.get('fromTable').value.value = fromId;
rowDroppedData.get('toTable').value.value = toId;
This doesn't look like it updates the actual values though, just locally stored ones.
Tried to explore the window object a bit more but wasn't able to figure it out.
Is this not possible?
Never mind, I figured out you just have to use the write function:
window.__client.page.sessionCustom.write('rowDroppedData.draggedId', draggedId)
Pretty slick stuff @victordcq!
Through trial and error I made some updates to get it working with multiple tables embedded in a flex repeater. The original injection script would only apply the update to last instance, no matter which table you were dragging and dropping on.
It required adding a domid property to the table in order to find the correct embedded table and making that unique via input param.
TableFlexRepeaterDragAndDrop.zip (111.2 KB)
	propName = "table.dragAndDrop"
	domid = self.view.params.domid
	code =  """<img style='display:none' src='/favicon.ico' onload=\"
		const view = [...window.__client.page.views._data.values()].find(view => view.value.mountPath == this.parentNode.parentNode.parentNode.getAttributeNode('data-component-path').value.split('.')[0]).value;
		const componentRoot = document.getElementById('domidInsert');
		if (componentRoot) {
			function ondrop(ev) {
				ev.preventDefault();
				const draggedId = ev.dataTransfer.getData('text');
				const droppedId = this.getAttribute('data-row-id');
				if (draggedId === droppedId) return;
				const droppedPayload = {'draggedId':draggedId, 'droppedId':droppedId, 'domid':'domidInsert'};
				view.custom.write('propNameInsert',droppedPayload);
			function ondragstart(ev){
				ev.dataTransfer.setData('text', ev.target.getAttribute('data-row-id'));
			function ondragover(ev){
			const setupRowListeners = (rootElement) => {
				rootElement.querySelectorAll('.tr-group.ia_table__rowGroup').forEach(e => {
					e.setAttribute('draggable',true);
					e.ondragstart = ondragstart;
					e.ondragover = ondragover;
					e.ondrop = ondrop;
			const callbackTable = (mutationList, observer) => {
				setupRowListeners(componentRoot);
			const observerTable = new MutationObserver(callbackTable);
			const tables = componentRoot.querySelectorAll('.t.ia_table > .tb');
			tables.forEach(table => observerTable.observe(table, { attributes: false, childList: true, subtree: true }));
	\"></img>""".replace('propNameInsert', propName).replace('domidInsert', domid).replace("\n", "").replace("\t", "")
	return code
wait input param? you are making this script for every table?
I think it would have been easier to grab the table id’s in the ā€œondragstartā€ and ā€ondropā€.
similar to ā€œev.target.getAttribute('data-row-id')ā€
you could use the ā€œclosest()ā€ css selector to find the element with the id on
Then you would only need one markdown script to run this and no need to inject the domidInsert.
But hey, if it works its fine ;p
You are correct its not optimal, however I use the table in multiple places so it was much easier to just create the script on one view :slight_smile:
