Easy char X trace Decimal limit
@lrose
Display date in title also getting false. i want to enable it
But I couldn't able to access that property through script
i user dir to get all the property. but i couldn't able to find it
Can you please help me to access that property through script
I thought you were using an Easy Chart?
Hovering the mouse cursor over the property reveals what it is, and the code word for X-Axis is Domain, so you have to get the domain axis and apply the scripting name there.
Example:
event.source.parent.getComponent('Chart').chart.plot.domainAxis.displayDayInTitle
Guess I missed that.
even for easy chart also it gone Fasle. thanks for the script
from java.text import SimpleDateFormat
	from org.jfree.chart.axis import DateAxis
	dateFormat = SimpleDateFormat("d MMM yyyy")
	timeFormat = SimpleDateFormat("HH:mm:ss")
	dateAxis = DateAxis()
	dateAxis.lowerMargin = 0
	dateAxis.upperMargin = 0
	plot = chart.getPlot()
	plot.setDomainAxis(dateAxis)
	plotDateField = plot.getClass().getDeclaredField('dateFormat')
	plotTimeField = plot.getClass().getDeclaredField('timeFormat')
	plotDateField.setAccessible(True)
	plotTimeField.setAccessible(True)
	plotDateField.set(plot,dateFormat)
	plotTimeField.set(plot,timeFormat)
	self.chart.plot.domainAxis.displayDayInTitle = 1
errro i am getting
14:45:41.133 [AWT-EventQueue-0] ERROR Vision.ClassicChart - Error invoking extension method.
org.python.core.PyException: AttributeError: 'org.jfree.chart.axis.DateAxis' object has no attribute 'displayDayInTitle'
at org.python.core.Py.AttributeError(Py.java:178)
at org.python.core.PyObject.noAttributeError(PyObject.java:965)
at org.python.core.PyObject.object___setattr__(PyObject.java:3821)
at org.python.core.PyObject.object___setattr__(PyObject.java:3792)
at org.python.core.PyObject$object___setattr___exposer.call(Unknown Source)
at org.python.core.PyObjectDerived.setattr(PyObjectDerived.java:1043)
at org.python.pycode.pyx23.configureChart$1(:29)
at org.python.pycode.pyx23.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.PyBaseCode.call(PyBaseCode.java:306)
at org.python.core.PyFunction.function___call
(PyFunction.java:474)
at org.python.core.PyFunction.call(PyFunction.java:469)
at org.python.core.PyFunction.call(PyFunction.java:459)
at org.python.core.PyFunction.call(PyFunction.java:454)
at com.inductiveautomation.vision.api.client.components.model.ExtensionFunction.invoke(ExtensionFunction.java:151)
at com.inductiveautomation.factorypmi.application.components.PMIChart.createChartImpl(PMIChart.java:481)
at com.inductiveautomation.factorypmi.application.components.chart.PMILineChartPanel.createChart(PMILineChartPanel.java:135)
at com.inductiveautomation.factorypmi.application.components.PMIChart.setExtensionFunctions(PMIChart.java:466)
at com.inductiveautomation.factorypmi.designer.eventhandling.ComponentScriptEditor.applyChanges(ComponentScriptEditor.java:596)
at com.inductiveautomation.factorypmi.designer.eventhandling.ComponentScriptEditor$5.actionPerformed(ComponentScriptEditor.java:337)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
14:45:41.460 [AWT-EventQueue-0] ERROR Vision.ClassicChart - Error invoking extension method.
at com.inductiveautomation.factorypmi.designer.eventhandling.ComponentScriptEditor$4.actionPerformed(ComponentScriptEditor.java:327)
The DateAxis object does not have an attribute 'displayDayInTitle'. This is because the Chart objects don't use the Standard JFreeChart DateAxis, but rather a Sub Class of it.
https://files.inductiveautomation.com/sdk/javadoc/ignition81/8.1.27/com/inductiveautomation/factorypmi/application/components/chart/AutoTickDisplayDateAxis.html#setDisplayDayInTitle(boolean)
Try this script instead:
	dateFormat = SimpleDateFormat("yyyy-MM-dd")
	dateAxis = chart.plot.domainAxis
	dateAxisDateField = dateAxis.getClass().getDeclaredField('dateFormat')
	dateAxisTimeField = dateAxis.getClass().getDeclaredField('timeFormat')
	dateAxisDateField.setAccessible(True)
	dateAxisTimeField.setAccessible(True)
	dateAxisDateField.set(dateAxis,dateFormat)
	dateAxisTimeField.set(dateAxis,timeFormat)
Note that in this script I am not overwriting the domainAxis, so any properties that you set in the chart configuration should work as set, and you shouldn't need to set them here.
Checked Its working perfectly thanks
