Edge backup turns into Full version
Yes I can,
#encoding=UTF-8
# Configuration files must begin with a line specifying the encoding
#  of the the file.
# Wrapper License Properties (Ignored by Community Edition)
# Professional and Standard Editions of the Wrapper require a valid
#  License Key to start.  Licenses can be purchased or a trial license
#  requested on the following pages:
# http://wrapper.tanukisoftware.com/purchase
# http://wrapper.tanukisoftware.com/trial
# Include file problems can be debugged by removing the first '#'
#  from the following line:
##include.debug
# The Wrapper will look for either of the following optional files for a
#  valid License Key.  License Key properties can optionally be included
#  directly in this configuration file.
#include ./wrapper-license.conf
# The following property will output information about which License Key(s)
#  are being found, and can aid in resolving any licensing problems.
#wrapper.license.debug=TRUE
# Wrapper Localization
# Specify the locale which the Wrapper should use.  By default the system
#  locale is used.
#wrapper.lang=en_US # en_US or ja_JP
# Specify the location of the Wrapper's language resources.  If these are
#  missing, the Wrapper will default to the en_US locale.
wrapper.lang.folder=../lang
# Wrapper Java Properties
# Java Application
#  Locate the java binary on the system PATH:
#  Specify a specific java binary:
set.JAVA_HOME=@libdir@/runtime/jre-win
wrapper.java.command=@java_executable@
# Tell the Wrapper to log the full generated Java command line.
#wrapper.java.command.loglevel=INFO
# Java Main class.  This class must implement the WrapperListener interface
#  or guarantee that the WrapperManager class is initialized.  Helper
#  classes are provided to do this for you.  See the Integration section
#  of the documentation for details.
wrapper.java.mainclass=org.tanukisoftware.wrapper.WrapperSimpleApp
# Java Classpath (include wrapper.jar)  Add class path elements as
#  needed starting from 1
wrapper.java.classpath.1=@libdir@/wrapper.jar
wrapper.java.classpath.2=@libdir@/core/common/*
wrapper.java.classpath.3=@libdir@/core/gateway/*
# Java Library Path (location of Wrapper.DLL or libwrapper.so)
wrapper.java.library.path.1=@libdir@
wrapper.java.library.path.2=@libdir@/core/gateway
# Java Bits.  On applicable platforms, tells the JVM to run in 32 or 64-bit mode.
#wrapper.java.additional.auto_bits=TRUE
wrapper.java.additional.auto_bits.macosx=FALSE
# Java Additional Parameters
wrapper.java.additional.1=-Ddata.dir=@datadir@
#wrapper.java.additional.2=-Xdebug
#wrapper.java.additional.3=-Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=*:8000
wrapper.java.additional.2=--add-opens=java.base/java.lang=ALL-UNNAMED
wrapper.java.additional.3=--add-opens=java.base/java.security.cert=ALL-UNNAMED
wrapper.java.additional.4=--add-opens=java.base/java.util=ALL-UNNAMED
wrapper.java.additional.5=--add-opens=java.base/jdk.internal.misc=ALL-UNNAMED
wrapper.java.additional.6=--add-opens=java.base/java.io=ALL-UNNAMED
# Initial Java Heap Size (in MB)
wrapper.java.initmemory=1024
# Maximum Java Heap Size (in MB) increaase to 12gig
wrapper.java.maxmemory=12288
# Application parameters.  Add parameters as needed starting from 1
wrapper.app.parameter.1=com.inductiveautomation.catapult.Catapult
wrapper.shutdown.timeout=120
wrapper.jvm_exit.timeout=120
# Set this value to TRUE to allow ignition.conf to be reloaded when the JVM is restarted
wrapper.restart.reload_configuration=TRUE
# Wrapper Logging Properties
# Enables Debug output from the Wrapper.
wrapper.debug=TRUE
# Format of output for the console.  (See docs for formats)
wrapper.console.format=PM
# Log Level for console output.  (See docs for log levels)
wrapper.console.loglevel=INFO
# Log file to use for wrapper output logging.
wrapper.logfile=@logsdir@/wrapper.log
# Format of output for the log file.  (See docs for formats)
wrapper.logfile.format=LPTM
# Log Level for log file output.  (See docs for log levels)
wrapper.logfile.loglevel=INFO
# Maximum size that the log file will be allowed to grow to before
#  the log is rolled. Size is specified in bytes.  The default value
#  of 0, disables log rolling.  May abbreviate with the 'k' (kb) or
#  'm' (mb) suffix.  For example: 10m = 10 megabytes.
wrapper.logfile.maxsize=10m
# Maximum number of rolled log files which will be allowed before old
#  files are deleted.  The default value of 0 implies no limit.
wrapper.logfile.maxfiles=5
# Log Level for sys/event log output.  (See docs for log levels)
wrapper.syslog.loglevel=NONE
# Wrapper General Properties
# Allow for the use of non-contiguous numbered properties
wrapper.ignore_sequence_gaps=TRUE
# Title to use when running as a console
wrapper.console.title=Ignition Gateway
# Wrapper JVM Checks
# Detect DeadLocked Threads in the JVM. (Requires Standard Edition)
#wrapper.check.deadlock=TRUE
#wrapper.check.deadlock.interval=60
#wrapper.check.deadlock.action=RESTART
#wrapper.check.deadlock.output=FULL
# Out Of Memory detection.
#wrapper.filter.trigger.1000=java.lang.OutOfMemoryError
#wrapper.filter.action.1000=RESTART
#wrapper.filter.message.1000=The JVM has run out of memory.
wrapper.on_exit.default=SHUTDOWN
wrapper.on_exit.2=RESTART
# Wrapper Email Notifications. (Requires Professional Edition)
# Common Event Email settings.
#wrapper.event.default.email.debug=TRUE
#wrapper.event.default.email.smtp.host=<SMTP_Host>
#wrapper.event.default.email.smtp.port=25
#wrapper.event.default.email.subject=[%WRAPPER_HOSTNAME%:%WRAPPER_NAME%:%WRAPPER_EVENT_NAME%] Event Notification
#wrapper.event.default.email.sender=<Sender email>
#wrapper.event.default.email.recipient=<Recipient email>
# Configure the log attached to event emails.
#wrapper.event.default.email.attach_log=TRUE
#wrapper.event.default.email.maillog.lines=50
#wrapper.event.default.email.maillog.format=LPTM
#wrapper.event.default.email.maillog.loglevel=INFO
# Enable specific event emails.
#wrapper.event.wrapper_start.email=TRUE
#wrapper.event.jvm_prelaunch.email=TRUE
#wrapper.event.jvm_start.email=TRUE
#wrapper.event.jvm_started.email=TRUE
#wrapper.event.jvm_deadlock.email=TRUE
#wrapper.event.jvm_stop.email=TRUE
#wrapper.event.jvm_stopped.email=TRUE
#wrapper.event.jvm_restart.email=TRUE
#wrapper.event.jvm_failed_invocation.email=TRUE
#wrapper.event.jvm_max_failed_invocations.email=TRUE
#wrapper.event.jvm_kill.email=TRUE
#wrapper.event.jvm_killed.email=TRUE
#wrapper.event.jvm_unexpected_exit.email=TRUE
#wrapper.event.wrapper_stop.email=TRUE
# Specify custom mail content
wrapper.event.jvm_restart.email.body=The JVM was restarted.\n\nPlease check on its status.\n
# Wrapper Windows NT/2000/XP Service Properties
# WARNING - Do not modify any of these properties when an application
#  using this configuration file has been installed as a service.
#  Please uninstall the service before modifying this section.  The
#  service can then be reinstalled.
# Name of the service
wrapper.name=Ignition
# Display name of the service
wrapper.displayname=Ignition
# Description of the service
wrapper.description=Ignition Gateway
# Service dependencies.  Add dependencies as needed starting from 1
wrapper.ntservice.dependency.1=
# Mode in which the service is installed.  AUTO_START, DELAY_START or DEMAND_START
wrapper.ntservice.starttype=AUTO_START
# Allow the service to interact with the desktop.
wrapper.ntservice.interactive=false
# Shared drive ---- Procix
wrapper.share.1.location=\\clmfp001.climatemaster.lsb-okc.com\CLM_DEPTS\Manufacturing\procix
wrapper.share.1.target=L:
wrapper.share.1.type=DISK
wrapper.share.1.startup.max_retries=2
#VERSION - DO NOT MODIFY: 15
Do you have an instance where the back up would be doing that? I've not modified the files in any way.
You should also set your initmemory to 12288 to match the maxmemory setting.
Are you sure you installed the edge version on the PC and not the standard edition when going through the initial setup? It's easy to click the wrong button (I've done it).
Was this .conf file pulled from the gwbk? It doesn't seem to match the previous conf file you mentioned. I don't see any edge parameter here.
I was looking to see if there was an extra parameter after the one for edge with a number lower than 7. Then you would just needed to modify the numbering.
I haven't seen the process of generating a gwbk modify those parameters before.
Sorry, that was the main gateway. Here is the Edge device
#encoding=UTF-8
#  of the the file.
##include.debug
#  locale is used.
# Java Application
set.JAVA_HOME=@libdir@/runtime/jre-arm32hf
wrapper.java.additional.7=-Dedition=edge
wrapper.java.additional.8=-XX:+UseG1GC
wrapper.java.additional.5=-Djava.io.tmpdir=jre-tmp
wrapper.java.initmemory=128
wrapper.java.maxmemory=1024
# wrapper.debug=TRUE
wrapper.displayname=Ignition Gateway
#VERSION - DO NOT MODIFY: 13
This ^
If you change the order of these params to move number 5 above the edge param it should fix the issue. You could also modify the numbering, to make sure the number increases with each new parameter. Either one of these should work.
wrapper.java.additional.4=-Dedition=edge
wrapper.java.additional.5=-XX:+UseG1GC
wrapper.java.additional.6=-Djava.io.tmpdir=jre-tmp
I'm late to this discussion, but Opto 22 has posted this KB article addressing the "Edge backup turns into full Gateway" issue.
Title: Ignition edition set incorrectly for Ignition 8 after upgrading firmware to version 4.0.0.
Of course, suppose you have SSH access to your groov EPIC (freely available). In that case, you can edit your ignition.conf file directly to correct the issue (as documented above) rather than download the GWBK Fix Utility and run your .gwbk file through it.
Opto 22 product support is free, including for Ignition Edge. So please reach out for assistance anytime.
Cheers, -Benson
https://www.opto22.com/support/resources-tools/knowledgebase/kb91207
