ERROR Vision.Components.AdvancedTable - Error invoking extension method.
org.python.core.PyException: Traceback (most recent call last):
File "<extension-method onCellEdited>", line 25, in onCellEdited
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:362)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:258)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(UPDATE AguaControl.Agua SET Consumo_Total = ? WHERE id = ?, [32, 25], AguaControl, , false, false)
at org.python.core.Py.JavaError(Py.java:495)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:429)
at org.python.core.PyObject.__call__(PyObject.java:422)
at org.python.core.PyObject.__call__(PyObject.java:426)
at org.python.pycode._pyx384.onCellEdited$1(<extension-method onCellEdited>:26)
at org.python.pycode._pyx384.call_function(<extension-method onCellEdited>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.PyBaseCode.call(PyBaseCode.java:301)
at org.python.core.PyFunction.function___call__(PyFunction.java:376)
at org.python.core.PyFunction.__call__(PyFunction.java:371)
at org.python.core.PyFunction.__call__(PyFunction.java:361)
at org.python.core.PyFunction.__call__(PyFunction.java:356)
at com.inductiveautomation.vision.api.client.components.model.ExtensionFunction.invoke(ExtensionFunction.java:152)
at com.inductiveautomation.factorypmi.application.components.VisionAdvancedTable$Model.setValueAt(VisionAdvancedTable.java:1744)
at com.jidesoft.grid.TableModelWrapperImpl.setValueAt(Unknown Source)
at com.jidesoft.grid.DefaultTableModelWrapper.setValueAt(Unknown Source)
at javax.swing.JTable.setValueAt(Unknown Source)
at com.jidesoft.grid.JideTable.editingStopped(Unknown Source)
at javax.swing.AbstractCellEditor.fireEditingStopped(Unknown Source)
at javax.swing.DefaultCellEditor$EditorDelegate.stopCellEditing(Unknown Source)
at javax.swing.DefaultCellEditor.stopCellEditing(Unknown Source)
at com.inductiveautomation.factorypmi.application.components.table.FormattedCellEditor.stopCellEditing(FormattedCellEditor.java:229)
at javax.swing.DefaultCellEditor$EditorDelegate.actionPerformed(Unknown Source)
at javax.swing.JTextField.fireActionPerformed(Unknown Source)
at javax.swing.JTextField.postActionEvent(Unknown Source)
at javax.swing.JTextField$NotifyAction.actionPerformed(Unknown Source)
at javax.swing.JFormattedTextField$CommitAction.actionPerformed(Unknown Source)
at javax.swing.SwingUtilities.notifyAction(Unknown Source)
at javax.swing.JComponent.processKeyBinding(Unknown Source)
at javax.swing.JComponent.processKeyBindings(Unknown Source)
at javax.swing.JComponent.processKeyEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.KeyboardFocusManager.redispatchEvent(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
Caused by: java.lang.Exception: Error executing system.db.runPrepUpdate(UPDATE AguaControl.Agua SET Consumo_Total = ? WHERE id = ?, [32, 25], AguaControl, , false, false)
... 71 common frames omitted
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Cannot run this function when in read-only mode.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:373)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:273)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:268)
at com.inductiveautomation.ignition.client.script.ClientDBUtilities._runPrepStmt(ClientDBUtilities.java:208)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:256)
... 69 common frames omitted
Your actual issue is:
Is your designer in read-only? Check under the menu Project and select "Comm Read/Write" and try it again.
OK, esta habilitado el modo Read/Write pero aun sigo con el error
OK post your entire error again.
