Consider using something like for i in range(Rtable.getRowCount()) at the top of the loop, and if i<(Rtable.getRowCount()-1) to allow for differing table sizes.
While we’re here, it’s a bit late now, but you can also convert BasicDatasets into PyDataSets which will make your life so much nicer when manipulating them, as you can use pythonic formats to read and write to them.
You can take a regular dataset and use this to convert it:
pds = system.dataset.toPyDataSet(ds) # pds = pyDataSet
pds[0]['columnA'] = "new value!"
Then you can convert it back with:
ds = system.dataset.toDataSet(pds)
