Excluding Weekends using DateTimeInput
No, the datepicker controls are based on someone else's code and have limited functionality. You can't even set Monday as the first day of the week.
As a workaround you can put a label beside the DateTime Input component and with an expression binding give the user a warning.
if(
  (getDayOfWeek({../DateTimeInput.props.value}) = 1)
  (getDayOfWeek({../DateTimeInput.props.value}) = 7),
  "Please select weekday!",
With a similar expression you could disable the "Save" button or whatever.
