Expression binding in prespective used in a transform-script
This doesn't make any since in the context of the title of the topic and the remainder of the post. Can you show what you are trying to achieve.
The Expression Language is not the same as the Scripting language.
There are many uses for an Expression structure. If you can explain what you are trying to accomplish as well as show what you have tried, then I'm sure that someone will be able to get you better assistance.
Also, be sure to follow this tip when posting scripts or expressions Wiki - how to post code on this forum.
