I tested this, and it seems that with an expression mapping, {value} is not a valid identifier in the expression.
Changing {value} to {view.custom.tempF} in each expression still did not work, which I figured should work. Adding one of the expressions to the fallback value, shows that the first expression is evaluating to true. ![]()
check these threads out for more details
Transform Map Expression Not working properly - Ignition - Inductive Automation Forum
Expression to color/StyleClass map transform example - Ignition - Inductive Automation Forum
