Expression into Indirect Tag Binding
Ah, but there is. It simply runs slower, because expressions built around it have to completely execute, even if only one little piece changes, and even if a given change wouldn't yield a change in the output. Totally aside from the (fixed?) bugs in its implementation in v8.0.
Gateway expression tags are the only place the tag() expression function makes sense.
