Expression Tags Help
That wouldn’t be part of your expression. That would have to be on the pump object itself. Normally you would have a state, which would be an int, on the pump object. This may be tied to a tag that provides the state or you could do an expression on the object itself. Then you would you styling for the object and set how the object responds based on different states.
If I was doing it with an object from Symbol Factory, I would do a custom property on the part of the pump that I want to change color. Then I would right click on it, go to customizers, then style customizer. From there you can set how your different states affect the pump.
I’m curious why there are udt instances created for all of the seemingly end tags? Are you able to show a screenshot of what’s inside of the Comm Fail tag, for example?
To me, this would be a nightmare trying to create a new device udt type, as you couldn’t simply create these by dragging on a udt type from the OPC browser and modifying it. It’d also be a nightmare trying to see the values of all the tags, as now you have to expand each of your individual tag udts :thinking:
