Favorite Ignition AI Applications / Implementation
I'm currently using Claude Code to accomplish something I've been wanting to for years, but never tackled because it is kind of a major undertaking...
Our MES has always been divided into two main projects, one for Production, and one for Secondary, but over time there has been a lot of overlap where both projects have their own version of essentially the same interface, and so their common functionality has been inside a third project that they both inherit from. I am constantly having to juggle my development across all three.
Many users regularly use both projects, and so shortly after I started working here I created a "wrapper" project that uses a side menu to navigate between the two, loading them inside iFrames. This has been clunky, and although I did manage a hacky workaround that automatically logs users into one project when they've already logged into the other, it is still kind of a pain to keep switching between the two.
I'm nearly finished having Claude consolidate it all into just one project, something I only started yesterday, and which otherwise would have taken me several days, if not weeks to pull off. Claude is quite knowledgeable about Perspective, and is able to build me patch ZIPs that I then import into my Designer to test.
I also recently used CC to build an Organizational Chart for Perspective that is on the Exchange. It uses Markdown JavaScript injection, which is an endangered species, and so I plan on getting help from Claude to convert it into a proper Module.
Just one year ago I was saying this about AI:
It can be useful for cleaning up existing code, but I wouldn't trust it much beyond that with Ignition
