[Feature-6615]New DT DateTime datatype in Logix
I've been chasing my tail all day on a similar issue w/ allen bradly's date time type. I have the plc data structure as follows:
I was having trouble getting the date time to read properly so I pivoted to just pulling the Raw Lint and then FromMillis() it back into a datetime. Now here's the interesting part, when i try to pull in that raw unix timestamp LINT this is what i get
Notice from the first screenshot that that 11 million number is the exact same as the Time32 and in fact not the lint I was trying to pull.
Has anyone seen this before? Any thoughts?
Thank you!
Possible bug. You should open a support ticket.
You might also want to try my alternate driver--different implementation:
What are you seeing when you just use the regular DT tag? What version of Ignition are you using?
The Proper DT tag (as a Long)
As a Date/Time
We are using v8.1.45
Bad news:
Activated without the Client Option? (Most users have that.)
If you have the client option, just create a "Generic EtherNet/IP Client" to replace the IA Logix device. (Use the same name.)
Phil, we are using the client option only and what @ethan.lewis is speaking to is the "Generic Ethernet/IP Client" and the results we are getting from Allen-Bradley DT type
So, not Kevin's problem at all. Please send an email to support@automation-pros.com so we can start evaluating this.
