Indeed, I messed up my tests when I tried it.
I used browse, as browseTags doesn't appear in the manual for 8.1 - I imagine it's been deprecated ?
Then I mixed things up, boinked it a bit more, and finally talked out of my ***.
Probably good not to use the deprecated function if I can avoid it, but I'm having a hard time converting it.
# get all tags in the analog folder
tags2 = [system.tag.browse("[default]Analog_Sensors", {'typeId':'Scaled_Analog_2SP'}).results]
tags4 = [system.tag.browse("[default]Analog_Sensors", {'typeId':'Scaled_Analog_4SP'}).results]
tags = tags2 + tags4
I think the last line here doesn't work to add together these lists for some reason
That last line simply joins two single-element lists, yielding a list of lists.
I thought so as well, but I actually had to use this to get it to work:
tags = tags2[0] + tags4[0]
**edit: Doh
it was my own brackets on the outside of the results making it a list of lists...
Interestingly, it also included a tag that is not the same UDT type in the list...
**edit: just now seeing this in the manual
final code:
tags2 = system.tag.browse("[default]Analog_Sensors", {'typeId':'Scaled_Analog_2SP', 'tagType':'udtInstance'}).results
tags4 = system.tag.browse("[default]Analog_Sensors", {'typeId':'Scaled_Analog_4SP', 'tagType':'udtInstance'}).results
# extract tag names and descriptions
names = [str(t['name']) for t in tags]
tag_paths = [str(t['fullPath']) + "/Parameters.Name_SA2SP" for t in tags]
desc = [str(d.value) for d in system.tag.readBlocking(tag_paths)]
# create dataset
headers = ["Description", "Tag Name"]
data = [[desc,name] for desc, name in zip(desc, names)]
dataset = system.dataset.toDataSet(headers, data)
print headers
print data
return dataset
results are exactly equal to what I had before
