Filter Dataset Based on Column Value
I am not seeing the Simulation Aids Module. Is that no longer available? Is there another way that people have been solving this?
Thank You,
The module is now referred to as Integrations Toolkit. Same module, more appropriate name.
As noted in the docs, I kept the original module ID "com.automation_pros.simaids" so that upgrades are seamless.
Although the view() expression still exists, Phil has since developed more expressions in this module that may make this process a bit more accessible.
See:
Have you checked out the post marked as a solution to this thread? If you can’t utilize a 3rd party module, I believe @paul-griffith’s post uses Ignition native scripting.
