Flex container and determining auto basis size
If you make the default height of the view shorter than needed (for example 10px) then it should work correctly with a basis of auto on the embedded view that its in.
This is probably a bug, but that’s the workaround I know of, often times I set a binding on defaultHeight to be something like 600 if the device is the designer, else 10
