After updating from version 8.1.19 to version 8.1.22 this issue came
INFO | jvm 1 | 2022/12/05 12:52:59 | True
INFO | jvm 1 | 2022/12/05 12:52:59 | Good
INFO | jvm 1 | 2022/12/05 12:52:59 | Mon Dec 05 12:52:29 EET 2022
INFO | jvm 1 | 2022/12/05 12:52:59 | True arvo
INFO | jvm 1 | 2022/12/05 12:53:00 | Scheduling logfile maintenance. Last maintenance: Mon Dec 05 12:51:58 EET 2022, events since then: 1
INFO | jvm 1 | 2022/12/05 12:53:00 | Starting logfile maintenance. Max entries: 50000, Max filesize: 104857600
INFO | jvm 1 | 2022/12/05 12:53:03 | E [c.i.i.g.l.SQLiteAppenderReader] [10:53:03]: Error executing query against logs database. route-group=status, route-path=/logs
INFO | jvm 1 | 2022/12/05 12:53:03 | java.sql.SQLException: Unable to build a valid query with the parameters provided.
INFO | jvm 1 | 2022/12/05 12:53:03 | at com.inductiveautomation.ignition.gateway.logging.SQLiteAppenderReader.buildPrepStatement(SQLiteAppenderReader.java:129)
INFO | jvm 1 | 2022/12/05 12:53:03 | at com.inductiveautomation.ignition.gateway.logging.SQLiteAppenderReader.query(SQLiteAppenderReader.java:154)
INFO | jvm 1 | 2022/12/05 12:53:03 | at com.inductiveautomation.ignition.gateway.logging.GatewayLoggingManagerImpl.queryLogEvents(GatewayLoggingManagerImpl.java:144)
INFO | jvm 1 | 2022/12/05 12:53:03 | at com.inductiveautomation.ignition.gateway.web.pages.status.routes.LoggingRoutes.getLogs(LoggingRoutes.java:561)
INFO | jvm 1 | 2022/12/05 12:53:03 | at com.inductiveautomation.ignition.gateway.dataroutes.Route.service(Route.java:254)
INFO | jvm 1 | 2022/12/05 12:53:03 | at com.inductiveautomation.ignition.gateway.dataroutes.RouteGroupImpl.service(RouteGroupImpl.java:61)
INFO | jvm 1 | 2022/12/05 12:53:03 | at com.inductiveautomation.ignition.gateway.dataroutes.RouteGroupCollectionServlet.serviceInternal(RouteGroupCollectionServlet.java:59)
INFO | jvm 1 | 2022/12/05 12:53:03 | at com.inductiveautomation.ignition.gateway.dataroutes.AbstractRouteGroupServlet.service(AbstractRouteGroupServlet.java:38)
INFO | jvm 1 | 2022/12/05 12:53:03 | at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1450)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1631)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:548)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
INFO | jvm 1 | 2022/12/05 12:53:03 | at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:322)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.server.Server.handle(Server.java:516)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:555)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:410)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:164)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
INFO | jvm 1 | 2022/12/05 12:53:03 | at java.base/java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2022/12/05 12:53:03 | Caused by: org.sqlite.SQLiteException: [SQLITE_BUSY] The database file is locked (database is locked)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.sqlite.core.DB.newSQLException(DB.java:1141)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.sqlite.core.DB.newSQLException(DB.java:1152)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.sqlite.core.DB.throwex(DB.java:1112)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.sqlite.core.NativeDB.prepare_utf8(Native Method)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.sqlite.core.NativeDB.prepare(NativeDB.java:117)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.sqlite.core.DB.prepare(DB.java:267)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.sqlite.core.CorePreparedStatement.<init>(CorePreparedStatement.java:44)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.sqlite.jdbc3.JDBC3PreparedStatement.<init>(JDBC3PreparedStatement.java:30)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.sqlite.jdbc4.JDBC4PreparedStatement.<init>(JDBC4PreparedStatement.java:25)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.sqlite.jdbc4.JDBC4Connection.prepareStatement(JDBC4Connection.java:34)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.sqlite.jdbc3.JDBC3Connection.prepareStatement(JDBC3Connection.java:155)
INFO | jvm 1 | 2022/12/05 12:53:03 | at org.sqlite.jdbc3.JDBC3Connection.prepareStatement(JDBC3Connection.java:135)
INFO | jvm 1 | 2022/12/05 12:53:03 | at com.inductiveautomation.ignition.gateway.logging.SQLiteAppenderReader.buildPrepStatement(SQLiteAppenderReader.java:110)
INFO | jvm 1 | 2022/12/05 12:53:03 | ... 52 common frames omitted
INFO | jvm 1 | 2022/12/05 12:53:05 | Cleaned up 500 rows in 5504 ms. Vacuum performed: true*
Is thre a way to handle this and what might be the root cause
