Absolutely just pass them as parameters to your next script.
def function1():
# really long script here
variable1='blah'
# etc with what you need to pass
someOtherLibraryScript.function2(variable1, variable2)
and then in your other function
def function2(param1, param2):
# param1 now has value of variable1 from script 1
# param2 now has value of variable1 from script 1
How long is your script exactly? I would highly recommend trying to break it down to smaller scripts. Take a look at this post for an example system.util.invokeLater or alternative function in global script? - #6 by bkarabinchak.psi
