Gateway Stopped - JVM appears hung
Follow up here in case anyone else runs across this problem.
JVM Hanging seems to be a resource based issue.
Kevin was on the right track suspecting Antivirus. But I was a little surprised that it turned out to be Microsoft Windows Defender. Since I have installed many gateways and never run into this issue. I typically leave Defender to “run out of the box”.
With Inductive support;
  • We examined the Windows event logs at the time of one of the gateway crashes we could see that Windows Defender had been scheduled to run around the same time.
  • Issuing a “Quick Scan” on Defender we were able to see the Gateway “restarting” multiple times. Defender appeared to get “stuck” on a file or location which froze the entire operating system ( i.e. File explorer would not navigate, Gateway web page was stuck ).
Further investigation
  • I was able to issue an exception ( do not include in scan in Defender setup ) on a couple of Windows Folders ( system32 , SysWOW64 ) and make it through the quick scan without causing a gateway restart.
  • I ran Defender Full scan and was able to cause the Gateway to “crash” despite those exceptions.
  • Defender does not have a very verbose system of reporting it’s execution. So it is hard to pinpoint the file or issue.
For further clarity on how the JVM wrapper operates on Java freezing see;
https://wrapper.tanukisoftware.com/doc/english/qna-freeze.html
https://wrapper.tanukisoftware.com/doc/english/prop-jvm-terminate-timeout.html
Excerpt
Not sure if these are the defaults with Ignition…
wrapper.ping.timeout=30
wrapper.ping.interval=5
wrapper.jvm_terminate.timeout=10
At this point in time I have no choice but to disable Windows Defender. I have temporaily installed Kaspersky, done a full scan which resulted in no viruses and the gateway ticking along no problem during a full scan.
