Gateway timer script to log folder of tags to SQL
Version 8.0.16
Your script worked using script console to run for a folder of tags.
output
[default]Hydraulic_Pressure/base1_acc_pressure 1438.41418457 Mon Jun 27 21:14:45 CEST 2022 Good
[default]Hydraulic_Pressure/base1_cb_pressure 1390.67675781 Mon Jun 27 21:14:57 CEST 2022 Good
[default]Hydraulic_Pressure/base2_acc_pressure 1452.05358887 Mon Jun 27 21:14:57 CEST 2022 Good
[default]Hydraulic_Pressure/base2_cb_pressure 1392.25048828 Mon Jun 27 21:14:57 CEST 2022 Good
[default]Hydraulic_Pressure/base3_acc_pressure 1448.38146973 Mon Jun 27 21:14:56 CEST 2022 Good
[default]Hydraulic_Pressure/base3_cb_pressure 1418.4798584 Mon Jun 27 21:14:56 CEST 2022 Good
Does the browse operation need to be recursive? In other words if the search finds a folder, do those tags also need to be included?
Taking some inspiration from @JordanCClark I did my best to refactor your code to accomplish what you’re attempting to do.
First here’s a little helper function which comes in handy for things like this. Technically you don’t need a function, but I find that grouper(2,zip(list1,list2)) is much more readable than
zip(*[iter(zip(list1,list2))] * 2). Some may disagree.
def grouper(n, iterable):
    return zip(*[iter(iterable)] * n)
This will group elements of an iterable in into groups of ‘n’ size. So
grouper(2,'ABCDEF') --> [('A','B'),('C','D'),('E','F')]
Here is what I came up with:
import numbers
def logDB_new(tags):
	tagReadList = []
	# Add fullpath of each tag, and each tag's Tooltip from the browse to the list.
	for tag in tags:
		tagReadList.append(str(tag['fullPath']))
		tagReadList.append(str(tag['fullPath']) + '.Tooltip')
	#Now that we have all of the paths we want, read all of the values in one go.
	qValues = system.tag.readBlocking(tagReadList)
	#create lists to hold the paths and values that we want to write after processing.
	writeList = []
	writeValues = []
	#create the base part of the query string.  This part will not change.
	query = "INSERT INTO 'ride_activeity_trends' ('Name','TagValue','t_stamp') VALUES "
	#create a list to hold the values to be inserted into the table.
	queryVals = []
	#Loop through the current and previous values.
	#The ZIP function puts the paths with the values, and the grouper function puts the currentPath and Value
	#together with the prevPath and value.  So you get something like (((currentPath,currentValue),(prevPath,prevValue)),...)
	for currentValues, prevValues in grouper(2,zip(tagReadList, qValues)):
		name, curQValue = currentValues  #break apart the currentValues into the path(name) and current qualified value
		prevName, prevQValue = prevValues#break apart the prevValues into the path(prevName) and previous qualified value
		#this insures that the value is a type of number. This prevents an error from trying to round a string or some other non-numeric type.
		if isinstance(prevQValue.value,numbers.Number):
			prevValue = round(prevQValue.value,3)
			curValue = curQValue.value
			#if the absolute value of prevValue is less then 0.1 or the current value is None then move on to the next itteration
			if abs(prevValue) <= 0.1 or not curValue:
				continue
			val_diff = abs((curQValue.value - prevValue)/prevValue)
			if val_diff > 0.1:
				#note that this is concatenating two lists resulting in a single list
				queryVals += [name,curValue,system.date.now()]
				#add the prevValue name and value to the lists to be written.
				writeList.append(prevName)
				writeValues.append(curQValue.value)
	#now that we have processed all of the tags we can construct the query.
	#the str.join() function returns a string by joining all elements of an iterable
	#the ['(?,?,?)'] * (len(queryVals) / 3 will dynamically create a list of ['(?,?,?)','(?,?,?)',...]
	#the number of elements in that list will be the length of queryVals divided by 3.
	#This will result in the syntax needed to insert the rows for all tags in one call.
	query += ','.join(['(?,?,?)'] * (len(queryVals) / 3))
	#only run the query if queryVals is not empty.
	if queryVals:
		system.db.runSFPrepUpdate(query,queryVals,datasources=['MySQL'])
	#write all of the tags in one go.
	system.tag.writeBlocking(writeList,writeValues)
tagPath = '[default]Hydraulic_Pressure'
tags = system.tag.browse(tagPath,{'tagType' : 'AtomicTag'}).getResults()
logDB_new(tags)
