Git functions (Designer Save) from Ignition Docker container
EDIT: Never mind. I ended up having to add a SWITCH user command to switch to root in order for it to work.
I’m trying to build the dockerfile and I’m getting permission denied errors.
=> ERROR [2/2] RUN apt-get update &&     DEBIAN_FRONTEND=noninteractive apt-get install -y --no-install-recommends         git &&             rm -rf /var/lib/apt/lists/*        0.2s
[2/2] RUN apt-get update &&     DEBIAN_FRONTEND=noninteractive apt-get install -y --no-install-recommends         git &&             rm -rf /var/lib/apt/lists/*:
0.207 Reading package lists...
0.215 E: List directory /var/lib/apt/lists/partial is missing. - Acquire (13: Permission denied)
Dockerfile:3
2 |     FROM inductiveautomation/ignition:${IGNITION_VERSION}
3 | >>> RUN apt-get update &&
4 | >>>     DEBIAN_FRONTEND=noninteractive apt-get install -y --no-install-recommends
5 | >>>         git &&
6 | >>>             rm -rf /var/lib/apt/lists/*
ERROR: failed to build: failed to solve: process "/bin/sh -c apt-get update &&     DEBIAN_FRONTEND=noninteractive apt-get install -y --no-install-recommends         git &&             rm -rf /var/lib/apt/lists/*" did not complete successfully: exit code: 100
Here’s my dockerfile:
ARG IGNITION_VERSION="8.3"
RUN apt-get update && \
    DEBIAN_FRONTEND=noninteractive apt-get install -y --no-install-recommends \
        git && \
Sounds like you got it resolved already, but yes, you can switch to root and do your system-level image manipulations and then return to the built-in ignition user afterwards, e.g.
ARG IGNITION_VERSION="8.3.2"
# Conduct system-level changes as root user
USER root
RUN apt-get update && ...
# Return to ignition user
USER ignition
