Gateway events sharing the same scope is an artifact of some backwards-compatibility decisions long ago. Generally, you would use a dictionary or similar defined in the top level of your project script. Those you can access by full name from elsewhere. (Elsewhere in the same scope, that is. “project library” isn’t a scope. Project libraries run in the scope they are called from.)
