Gradle plugin is missing module signer
Thank you,
Turns out I actually needed
pluginManagement {
    repositories {
        mavenLocal()
        gradlePluginPortal()
        maven {
            url 'https://nexus.inductiveautomation.com/repository/public'
Adding to my settings.gradle.
I have now ran into another issue when signing my module. The signModule task in gradle fails with the following error:
Unable to find method ''void com.inductiveautomation.ignitionsdk.ModuleSigner.<init>(java.security.PrivateKey, java.io.InputStream)''
Gradle's dependency cache may be corrupt (this sometimes occurs after a network connection timeout.)
Re-download dependencies and sync project (requires network)
The state of a Gradle build process (daemon) may be corrupt. Stopping all Gradle daemons may solve this problem.
Stop Gradle build processes (requires restart)
Your project may be using a third-party plugin which is not compatible with the other plugins in the project or the version of Gradle requested by the project.
In the case of corrupt Gradle processes, you can also try closing the IDE and then killing all Java processes.
I have tried the recommended fixes by Gradle, but I had no luck. Do you have any ideas?
If I can’t get it working, I may resort to the standalone module signer, although, the Gradle version would be nicer.
Thanks,
Tom
