If you can guarantee you'll only ever have one project you care about, sure, that's totally reasonable. My second thought is that I don't know if the project system ignores .git directories within the project or not.
My first thought was that if you ever have to change to VCSing multiple projects, it's going to be difficult/annoying to do that in a single transaction and preserve history on all your files. Maybe not a deal breaker - you could always have an archival repo and a brand new repo if you do end up needing to track multiple projects.
Sometimes I will, sometimes I won’t. If it’s a job with multiple projects I’d just make the repo the projects directory and use the .gitignore file like normal. It’s not that much of a pain anyway, so maybe it’s written that way because it’s just best practice to do things the same way every time.
That’s what gave me pause. I wasn’t sure how that would affect things. It doesn’t seem like it because the .git folder is hidden, but you never know. I guess the only thing to do is try and test, if it’s even worth it, and I’m doubting if it is.
With the release of 8.3, we now have a Version Control Guide on our docs page that may be useful. As part of the team who wrote the guide, it contains a lot of the same information included in the original post here, but updated for 8.3.
Thank you, Eric. This is a very comprehensive guide. I still struggle to see how the “additive approach” can be applied in a simple, practical way. I believe the real key would be integrating Git directly into the Designer. Without that, it seems difficult to fully take advantage of Git’s benefits. In this regard, you might draw some inspiration from SAP’s “transport requests.”
@Eric_Knorr Nice work, I have one recommendation for the project template, add “:rw” to the end of your project volume in your compose file. This allows you to manage your git commits much easier and also allows you to directly edit you gateway scripts in your IDE, so you can use tools like cursor ect.
I haven’t figured the correct way to reload the scripts back into designer, I often just restart the container since it only takes a few seconds in my dev environment.
@Eric_Knorr , I appreciate the guide. I’m running into an issue that seems tied to the bind mounts I defined for Git. Each time I run docker compose up to recreate a container, the startup takes a long time, and a new temporary user profile is generated—eventually leaving me with a long list of these profiles.
After experimenting, I found that adding a named volume alongside the Git bind mounts fixes the problem. Startup time improves, and no extra temporary user profiles are created.
@Craig_webber, when I discard changes in Git for a project and want to restore the original code in the Designer, I first trigger a project scan to update the Gateway.
There are two ways to do this in v8.3:
Use the API:
<ip>:<port>/data/api/v1/scan/projects
Call the system function to rescan the project folder:
system.project.requestScan([timeout])
Once the rescan completes, click the Merge Changes from Gateway button in the Designer (see screenshot below).
Hi Andrew, your method indeed does work, unless you destroy that volume. We have an internal ticket (IGN-14241) to streamline this process, but here's a little bit of insight on what is happening:
In order for Ignition to commission properly, the following need to exist:
Note: The resources in config can be overridden by a deployment mode, but the resource definition just has to exist somewhere)
Your approach works because the named volume persists commissioning.json and the core resource directories between container recreations. When you only bind-mount config/, these files don't exist yet on first startup, causing Ignition to create temporary profiles while attempting to commission.
A more robust solution is to use a bootstrap service that seeds the required files before Ignition starts. This way, you don't need to rely on a persistent volume that could be accidentally destroyed:
Eric, thanks for following up. I tried your approach, and it does work. On the first run, the Ignition Gateway fails to start up in the container, but after a restart everything comes up fine.
My only dislike with this solution is ending up with a stopped container for the bootstrap:
When I re-read your post, I realized the only thing missing for Ignition to properly commission was the commissioning.json file. To address this, I created a commissioning.json containing just {} and referenced it in my compose file:
With this setup, the first run still fails during commissioning but starts cleanly after a restart. From then on, there are no issues with the user profile when re-creating the gateway container, and I can safely commit the commissioning.json file into Git for team reuse. This also avoids the problem of losing a persisted volume, since a persisted volume is not in use in this approach.
Overall, this feels like a solid alternative approach , and I’m curious to see how things change once internal ticket IGN-14241 is resolved.
I realized that my docker compose setup did not allow for updating files in the container. I needed to change file permissions to enable Git operations. In my docker compose file, I now reference an entrypoint.sh script that updates the file permissions in the container before Ignition starts.
With these changes, I can now update container files through Git operations. For example, when I discard changes in Git, it properly reverts the changes in the container. I can then trigger a project scan to update the project in the gateway, and finally use Merge Changes from Gateway to sync those changes into the Designer.
I have been meaning to write up a simple guide, hopefully this answers your question. This was written in the context of how I develop with docker and Git. This is also written for developing against Ignition v8.3.x. Here's my first pass...
Environment setup for docker
This architecture provides a foundational setup for developers to work locally on Ignition projects while leveraging Git for version control.
The host machine OS is Windows 11 24H2 with the following software tools:
WSL2 Ubuntu 24.04.1 LTS
Rancher Desktop v1.20.0 - Container Engine-> dockerd(moby) - this allows for VS Code or Cursor to interact with the docker environment
Cursor v1.7.40 or Visual Studio Code v1.105.0 as the IDE for docker compose and Git commands
Container Tools (IDE extension for VS Code or Cursor) - this extension will hook into the docker engine for interaction in the IDE
Git for Windows
In this example I have a Git repo for the docker compose file and a separate Git repo for the Ignition gateway configuration and project data. Below is a base file structure for docker.
Thank you, this is nice, I will try to make use of the same and let you know, i was also planning to provide a small guidebook kind of thing after i did it completely.
my plan is to have a
OS: RHEL
Install Docker
Use docker desktop for easy access or even Portainer
install ignition, postgres, gitlab
Do we need to install the gitlab runner for this?
I’m planning to do it as a Dev and staging for ignition, and wanted to have the git to be involved for that process. For 8.3, since we have everything in the folder format, I guess this will be helpful.
A small question, @andrew.brauer do you have any comments on this plan? Something that i should have to keep in mind for this implementation or any challenge?
I’m buidling a ‘KISS' Portainer ‘GitOps’ edge ‘stack' + DevOps for project-level repo CD into named volumes. Would be nice if i could deploy an “empty” ignition container with separate config/project named/anonymous volumes and clone into them afterwards with a git-sync sidecar, but that’s not possible ATM. Criticism welcome of course
thoughts:
mounting empty volume to /projects fails with unable to create .resources dir
guessing due to similar issue above, data/* dir init doesn’t fire if it exists, assuming pre-seeding would work
named volumes/PVCs are best practice in orchestrated environments - might as well avoid bind-mounts in dev as well - the fact that “Advanced” section of the guide provides bind-mount examples alongside mentions of GitOps tools like Argo/Flux is surprising to me (though I’m admittedly a k8s noob, maybe I’m missing something)
historically the more OT-accessible Portainer didn’t support relative-path bind volume mounts for gitOps-based ‘stack’ deployment, without git, must seed the docker host with bind mount source data manually/via CD tools
well here’s some potential AI hallucination on the subject indicating it might not be as easy as i had hoped:
That .resources file failure is the tell-tale symptom: Ignition expects the projects/ folder to live inside the same volume as the rest of /usr/local/bin/ignition/data because it writes cross-directory metadata (.resources, project.json, etc.) using relative paths and Java NIO file handles. When you split projects/ into a second mounted volume, Ignition’s gateway service sees a mount boundary and can’t atomically create or lock the .resources file.
so it’s looking like no matter what I must clone/stage the project-level repos somewhere else like /tmp and then rsync them over (if using git_sync sidecar)
Since the release of Ignition 8.3, we’ve received many questions about how to approach CI/CD effectively. In this video, I walk through practical strategies and lessons learned to help you implement it with confidence.
Hey all, I have finally gotten around to refreshing these guides for 8.3. At the same time, I took the opportunity to just migrate them into a single repo.
My intention is to continue to add additional guides exploring more than just version control and containerization, but also other advanced topics around Ignition like Kubernetes, DevOps, GitOps, or whatever other topics you'd like to see. Feel free to submit an issue with ideas/suggestions/corrections.
Would appreciate any thoughts around Mono vs Multi-repo architectures. Diagram aid included (link)
here are some intial thoughts:
keeping shared projects/modes identical across gateways/environments is difficult in a Monorepo (I tried indicating they were "linked" in the diagram but it re-flowed horribly)
