Has anyone made an ORM work with Ignition transaction groups?
I've long been using a "SmartMap" extended dictionary that naturally allows property access to dictionary content. Create one with a tuple sequence of colName/colValue pairs and you suddenly have a very ORM-like row object. The one I like most delivers a None for missing keys automatically:
# Handy tool for objects as "bags of properties"
# by Peter Norvig, enhanced as a subclass of dict() by Philip J. Turmel
# http://norvig.com/python-iaq.html
class SmartMap(dict):
	def __repr__(self):
		args = []
		for (k,v) in self.items():
			if isinstance(v, basestring):
				args.append('%s=%s' % (k, v))
			else:
				try:
					z = len(v)
					args.append('%s=%s' % (k, type(v)))
				except:
					args.append('%s=%s' % (k, repr(v)))
		return 'SmartMap(%s)' % ', '.join(args)
	def __str__(self):
		args = []
		for k,v in self.items():
			else:
				try:
					z = len(v)
				except:
					args.append('%s=%s' % (k, str(v)))
	def clone(self):
		return type(self)(**self)
	def __getattr__(self, attr):
		if attr.startswith('__'):
			raise AttributeError(attr)
		if attr in self:
			return self[attr]
		return None
	def __setattr__(self, attr, val):
			super.__setattr__(self, attr, val)
		self[attr] = val
If you have a dataset ds and rowNum, you can load that row into this model like so:
row = util.SmartMap(zip(ds.columnNames, [ds.getValueAt(rowNum, i) for i in range(ds.columnCount)]))
If you consistently use column names that are valid python identifiers (and you do, right?), everything in the row is now accessible as either row.colName or row["colName"], as needed.
I'd be delighted if the future PyDataset Jython proxy supported this syntax in its row iterator...
