Another way to approach this problem, if you have access to SQL Server Management Server is to Create a View using the SQL QUERY provided by IRose without the WHERE And ORDER BY clause.
Then you can use a simple SELECT Query to access your data and the VIEW is reusable
You can look up the Syntax on docs.microsoft.com or in any SQL book but it is basically putting
Create View [dbo].[vViewName] as in front of your SQL statement
This eliminates the need for table C and rejoining the tables anytime you need to access the data
Matt
