Meh. I don't trust that 100% stat in the ENBT. Flaky junk. I have to admit that I jerk them out at first opportunity. The EN2T is much better.
Things to try in the meantime:
Run your concurrency up on your drivers. You have ~128 CIP connections to work with. Consider 12-ish for each of the seven CPUs.
Split UDTs out of your AOIs as described in the linked topic, if practical.
Anything else in the AOIs that is display-only or configuration or tuning, move to a leased group or scan class.
And I would be remiss if I failed to mention the option to use class one connections–I/O or producer/consumer–via my module:
https://inductiveautomation.com/moduleshowcase/module/automation-professionals-llc-ethernetip-class-1-communications
Class one CIP connections seem to be a much lighter load on the PLC and comm cards even with blistering RPI settings.
Only reason I went looking into this is because the citect driver that was also looking at the same PLC kept crashing. AFAIK this hasn’t occurred on the live system, but I am cautious of it. Thanks for your suggestions on how to improve things. Modifying the polling to be a bit smarter is probably the most practical option moving forward.
