How many tags can tag.readBlocking handling?
First, this appears to be in a tag change event. You should avoid long running scripts in tag change events. I would recommend that you refactor this to be used with a Gateway Tag Change Event.
This is due to the way that Tag Change Events work. You can read more on that here:
Second, you should be using system.runPrepUpdate()
from itertools import chain
if  not initialChange:
    logstart = system.date.now()
    logger = system.util.getLogger("Heartbeat event trigger")
    oktoreadpath = '[default]_tmp/_HeartBeat_event_monitoring/ReadAreaOk2Read'
    ReadLengthpath = '[default]_tmp/_HeartBeat_event_monitoring/ReadLength'
    dbresultpath = '[default]_tmp/_HeartBeat_event_monitoring/DBResult'
    paths =  [oktoreadpath,ReadLengthpath]
    [oktosend , readlength] = system.tag.readBlocking(paths)
    readlength = readlength.value
    if oktosend.value == 1 and readlength >0:
        parentPath = '[default]_tmp/_HeartBeat_event_monitoring/_HeartBeat_event_read/_DPP_Read_HBEvent_{}_/'
        eventpaths = [pPath + name for pPath in [parentPath.format(e) for e in range(readlength)] for name in ['Integer00','Integer01','Integer02','Integer03','TimeInBuffer']]
        taglist = system.tag.readBlocking(eventpaths)
        querystring = "INSERT INTO heartbeat_event (equipid,heartbeatc,heartbeatp,tsc,createdate,logid) values "
        querystring += ','.join(['(?,?,?,?,?,?)'] * (readlength / 5))
        querystring += ';'
        def step(xs):
            start = 0
            step = 5
            for x in xs:
                if start > (len(xs)-step):
                    break
                yield (start, xs[start])
                start += step
        eventlist = list(chain.from_iterable([[taglist[y].value,taglist[y+1].value,taglist[y+2].value,system.date.addMillis(currentValue.timestamp,taglist[y+4].value*(-1),currentValue.timestamp, taglist[y+3].value] for y,tag in step(taglist)]))
    system.db.runPrepUpdate(querystring,eventlist,_dataBase)
    logstop = system.date.now()
    logger.info("heart beat trigger end successed take {}ms".format(system.date.millisBetween(logstart,logstop))
