@Transistor @schenk @victordcq
Thank you all for the support.
The script and the logout action are now working fine!
These are the steps that I have followed:
- I created two session props ‘idletime’ and ‘timeout’.
- Created an integer memory tag with the name ‘idletime’ and bind it with numeric entry perspective component.
- Binded the session property ‘timeout’ with the ‘idletime tag’
- Expression binding on ‘idletime’ session prop:
now(1000) - {session.props.lastActivity} > {this.custom.timeout}
and in change property script:
if currentValue.value == True:
system.perspective.closeSession()
else:
return currentValue
- Entering time in milliseconds in numeric entry. When lapsed seconds > user input seconds then the session is closed and user need to login to view the page again.
