Part of the point of open source is to fix this problem, because if the original source stops publishing, the source code can be forked and maintained by anyone who needs it. Collaboratively, typically.
As for PostgreSQL, you should know that it is financially supported by a bunch of big companies that depend on it, like Google and Amazon. (Google's Big Data and Amazon's RedShift are both tweaked and rebranded derivatives of PostgreSQL.) PostgreSQL is probably the open source project least likely to be abandoned.
Any conflict between Windows and PostgreSQL I would lay at Microsoft's feet. MS has a long history of anti-competitive behavior, and PostgreSQL is a huge commercial threat to their DB platforms. (One of the many reasons I consider Windows on the production floor to be engineering malpractice.)
The Ignition system is not really doing anything else other than historizing data and the CPU idles at 3-4%. If I have the Ignition system overview screens and a few Perspective screens used for testing open, the CPU idle is about 35%.
Once the system is setup, none of those screens need to be left open and no one will be running them remotely. No process screens or trends or multiple users to support.
When the POST script runs the CPU usages spiks to 100% for a few seconds.
For this use case, would moving the MSSQL database to another VM make as much of a difference?
Hmm... "8.3 adds a built in historical logging time series database that can handle time series data much better than what is available in 8.1."
SCADA and database workloads have incompatible CPU and RAM utilization behavior. This may be tolerable in a training or test or development environment, but is not appropriate for production environments.
Move the DB to a different system. If moving to a different VM in the same hypervisor, make sure the hypervisor is set up for low latency, and is not overcommitted. Per IA's VM deployment guidance. (Commercial hypervisors are typically not correctly configured out of the box.)
11 million rows is not a lot for any database engine, 11B then yes understandable it would be slow.
Here are some talking points.
Like Paul mentions, your DB should be on its own dedicated VM with adequate resources. You also get the convenience of being able to maintain and restart your DB and not SCADA at the same time and vice versa. There is no excuse to have your DB on the same box as SCADA unless you have a very small simple system.
Partitioning is an excellent way to improve query performance. You could easily switch to weekly partitions or even set up a history splitter and feed a DB with daily partitions. This can drastically improve performance. If partitioning does not speed up your queries something else is wrong.
Setting up or tuning DB indexes can greatly improve query performance.
If you want to have only a single partition so that external apps can access your ignition historical data, the option I would use is Timescale DB on top of Postgres. Your data will be stored in a single partition, but how TImescale DB works is it essentially creates virtual partitions with indexing. This is configurable so you can set the chunks to be minutes, hours, or days. By the way Postgres has been around as long as MSSQLServer and it is wildly popular, it runs on windows just as reliably as anything else.
At some scale it is better to let Ignition do the SCADA part and let something else do the heavy history queries straight to the DB. If you have these queries in stored procedures the SQL query plans can make these many times faster than ad-hoc queries from Ignition.
Thanks for the post and I've seen these suggestions in a few different threads but some seem to not apply and or don't have an easy way to test.
Also just wondering which ones will help or help the most. In the order you listed?
Move the MSSQL to another server.
Partitioning?
Pre-Processed partitions, if not looking for raw values or all values in the last minute.
DB Indexes.
Move to Timescale DB on top of Postgres. Probably higher on the list.
Stored procedures.
"11 million rows is not a lot for any database engine"
That is why I was not initially worried about everything being on the same server. I did not think we were doing anything that intense (no process screens or remote/any users etc.) and I thought getting the data quired from the same server would be a plus. But it seems that even if Ignition is only doing historical logging, you still want the database on a different server. If it makes the queries faster and system more stable it's totally worth it but it feels like overkill on a system that is idle at 2-4% CPU unless a query is running.
Changing when and where some of the script is run, it went from almost a minute to query data for the 8000 tags and POST them, to about 15 seconds. That 15 seconds is close to just running the only the query with a known list of tags, without getting the data ready to POST and so on. Then without changing anything else and just splitting the query into four threads, the four queries finish in around 6-8 seconds. With one large query all cores on the server jump to 100%, with the four queries in their own threads in Ignition all cores also jump to 100% but the same data is read in about half the time. So it feels like the setup as is, could query the data faster.
I did try changing the partition size from one month to an hour and there was no change in the query time. Is there an issue changing the setting back and forth? Maybe I need to reset/delete all the tables after making the change.
This isn't a good measure of load. We have a system with 500k tags in split architecture with 95 vision clients and 40 perspective clients, with the front end sitting at 2.5% cpu
All clients active, everything all on one server? I also look at CPU, RAM, Disk activity, Network activity, errors, stability, responsiveness and so on. It's just how I felt at the time, no big red flags and nothing to compare the query times to.
Correct. Ignition is latency sensitive, and needs nearly idle cores (some) to work well. When running in the same system, DBs steal all the idle cores, crushing Ignition. That's what I meant by incompatible workloads.
Just to throw in my experience. We compared side-by-side MSSQL and TimescaleDB and they had the same performance. We followed the recommendations from IA when setting up TimescaleDB. We spent about 3 days tinkering with settings and even reimported all of the data into TimescaleDB using a different tick setting. All that to say it seems like TimescaleDB takes quite a bit of expertise and tuning to make it perform the way @bkarabinchak.psi is talking about.
That's interesting, when I installed TimeScaleDB on my headless ubuntu server it asked me about setup, it auto-suggested using 75% of the available ram etc. It was a very easy setup once I get to that part. I just accepted all the suggestions.
You do have to make sure you use hyptertables iirc to take advantage of the point of TimeScaleDB.
Edit: Now I recall, I used timescaledb-tune to optimize the hardware config.
They're getting ready to set up a carbon copy application and I'm having trouble deciding which way to go database wise.
If what I read is correct and or am understanding it correctly, 8.3 now has QuestDB that can run very efficiently on the local gateway. I believe that it should be an easy transition as I'm using Ignition functions in all the scripts but I may have something in there somewhere where I'm using an SQL based command of some kind that cpould cause issues with the existing scripts.
I was thinking I could use SQLite for some simple local logging tables that had been in the MSSQL database that was installed on the same gateway server. Then use QuestDB on the same local gateway as its performance is supposed to be significantly better then the MSSQL service and its demands on the system.
I had even seen a recommendation that QuestDB is efficient enough that keeping it local would be more efficient than installing QuestDB on a remote server and sending it a query and getting back the data and then sending it back out again through the REST API.
If I don't change anything it seems like the recommendation is still to put MSSQL on its own server even though I might see some latency hits from requesting data from the remote server?
If you're considering using any historian on the same server as Ignition, then use the Core Historian / Quest DB. The transition from any previous historian to Core Historian should be a very easy one (name your Core Historian the same name as your previous).
We have a couple of apps running with the Core Historian and have not seen any performance bottlenecks. Then again, we transitioned these apps over from a SQLite historian...so, gains were expected. As can be assumed, these are pretty low data collection gateways (<1GB/month), and loss of data is acceptable...priority is 'easy to deploy and maintain'.
Keep in mind that the QuestDB in Ignition is not exposed as a general database connection. It is only a historian. It is dramatically better than the SQLite-based internal historian, but is not a substitute for proper external DB platforms. Especially if redundancy is involved. And, IIUC, proper external DBs can be souped up to outperform the Core Historian (which cannot run outside Ignition).
Redundancy support for the Core Historian is supposed to be on the way, but I haven't seen a promised timeline.
(The optional localhost port to access the QuestDB, via a postgresql-compatible driver, is not full-featured.)
