How to set in a TimeSeriesChart the Y-Axis range?
Double check to make sure that you have assigned the series and axis values under the trends property.
You have to set the series and axis properties under plots.trends to whatever you have your Y axis settings named and your series named to get the Y axis to be overridden from the auto range to the settings you want to display.
There is more information in this older post as well.
