How to set the tag quality in Python scripting in the WebDev module?
I'm gonna test that right now
edit:
Doesn't seem to work. I can write just fine to tag.quality but it doesn't seem to change the quality.
qpaths = ["{}.quality".format(p) for p in paths]
qualities = [getattr(QualityCode, q, 'Uncertain') for q in qualities]
qualities
system.tag.writeBlocking(qpaths, qualities)
system.tag.readBlocking(paths)
gives me this:
[Bad_Stale, Bad]
[Good, Good]
[[24, Good, Tue May 03 16:30:23 CEST 2022 (1651588223563)], [42, Good, Tue May 03 16:30:33 CEST 2022 (1651588233940)]]
Ok, I found the Script Console... Sorry, newbie at Ignition...
from com.inductiveautomation.ignition.common.model.values import BasicQualifiedValue, QualityCode
paths = "[SolidRed]/Path/To/Device/MyString"
values = system.tag.readBlocking(paths)
qualities = { "Bad" }
qvals = [qv.derive(getattr(QualityCode, quality, 'Uncertain')) for qv, quality in zip(values, qualities)]
values
qualities
qvals
result = system.tag.writeBlocking(paths, qvals)
Gives:
[[MyString, Good, Tue May 03 09:13:32 CEST 2022 (1651562012495)]]
set(['Bad'])
[[MyString, Bad, Tue May 03 09:13:32 CEST 2022 (1651562012495)]]
Which looks good to me.
And a popup with the following error message:
Error writing to tag(s): Gateway Comm Mode is not Read/Write.
Edit:
Got it fixed with:
system.util.setConnectionMode( 3 )
It is actually working from the Script Console and not from Web Dev. Have to investigate further...
Edit 2:
Ok, got it working in Web Dev as well. Probably did something wrong earlier...
Minor bug:
qvals = [qv.derive(getattr(QualityCode, quality, "Uncertain")) for qv, quality in zip(values, qualities)]
should be:
qvals = [qv.derive(getattr(QualityCode, quality, getattr(QualityCode, "Uncertain"))) for qv, quality in zip(values, qualities)]
You're right, though QualityCode.Uncertain seems simpler than getattr(QualityCode, "Uncertain")
Even better... :grinning:
Thank you for your help! Much appreciated!
