[IGN-12538]Custom Session Properties Gone
We're tracking this issue internally at a high priority, but so far haven't been able to reproduce it reliably enough to isolate the root cause.
At the current time, we're planning to fix it in 8.1 and "forward port" to 8.3.
Adding my experience with 8.3 in case its useful. I’ve had this issue happen three times now, when I try to save in the Designer, I get the error below. In the past, when this error has occurred, I’ve lost all my session props after reopening the Designer.
However, this time when the error came up, I had another developer working in the same project try to save, and he was able to save successfully. When I reopened my Designer afterward, my session props were still intact.
Not sure if this points to something with individual Designer instances or gateway communication, but figured I’d share in case it helps.
java.util.concurrent.ExecutionException: java.util.NoSuchElementException: No value present
	at java.base/java.util.concurrent.CompletableFuture.reportGet(Unknown Source)
	at java.base/java.util.concurrent.CompletableFuture.get(Unknown Source)
	at com.inductiveautomation.perspective.designer.workspace.pageconfig.SessionPropsAdapter.commit(SessionPropsAdapter.java:212)
	at com.inductiveautomation.perspective.designer.workspace.pageconfig.WorkspaceRootConfig.commit(WorkspaceRootConfig.java:22)
	at com.inductiveautomation.perspective.designer.workspace.ViewWorkspace.notifyProjectSaveStart(ViewWorkspace.java:398)
	at com.inductiveautomation.perspective.designer.DesignerHook.notifyProjectSaveStart(DesignerHook.java:638)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.lambda$getCommitTasks$46(IgnitionDesigner.java:1667)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.lambda$commitAll$41(IgnitionDesigner.java:1618)
	at java.base/java.util.stream.ReferencePipeline$3$1.accept(Unknown Source)
	at java.base/java.util.ArrayList$ArrayListSpliterator.forEachRemaining(Unknown Source)
	at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
	at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
	at java.base/java.util.stream.ReduceOps$ReduceOp.evaluateSequential(Unknown Source)
	at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
	at java.base/java.util.stream.ReferencePipeline.reduce(Unknown Source)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.commitAll(IgnitionDesigner.java:1626)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.handleSave(IgnitionDesigner.java:1377)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler.lambda$handleSaveAction$12(IgnitionDesigner.java:2668)
	at com.inductiveautomation.ignition.client.util.gui.progress.Task$FunctionWrapper.apply(Task.java:247)
	at com.inductiveautomation.ignition.client.util.gui.progress.Task$FunctionWrapper.apply(Task.java:237)
	at com.inductiveautomation.ignition.client.util.gui.progress.Task.lambda$runInternal$3(Task.java:205)
Caused by: java.util.NoSuchElementException: No value present
	at java.base/java.util.Optional.orElseThrow(Unknown Source)
	at com.inductiveautomation.perspective.designer.workspace.pageconfig.SessionPropsAdapter.lambda$commit$10(SessionPropsAdapter.java:211)
	at java.base/java.util.concurrent.CompletableFuture$UniApply.tryFire(Unknown Source)
	at java.base/java.util.concurrent.CompletableFuture.postComplete(Unknown Source)
	at java.base/java.util.concurrent.CompletableFuture.complete(Unknown Source)
	at com.inductiveautomation.perspective.designer.workspace.JavaJsBridge.lambda$invokeFunction$2(JavaJsBridge.java:288)
	at com.teamdev.jxbrowser.frame.internal.FrameImpl$1.onNext(FrameImpl.java:359)
	at com.teamdev.jxbrowser.frame.internal.FrameImpl$1.onNext(FrameImpl.java:355)
	at com.teamdev.jxbrowser.internal.rpc.ServiceConnectionImpl.lambda$invokeAsync$6(ServiceConnectionImpl.java:229)
	at com.teamdev.jxbrowser.internal.RpcThreadImpl$TaskRunner.processTasks(RpcThreadImpl.java:175)
	... 1 more
I ran into this issue today, PC server hosting a gateway was rebooted and all of the session custom props have disappeared. This is very concerning as it had multiple bindings that are crucial to making the application function. Any response from IA on how to fix this issue?
I found this thread when trying to create new session custom properties in a mostly empty project, one I had created a few days before and had left the designer open. I created a custom session property, navigated away from the session/page configuration screen to a view I had open, then returned and saw the property did not exist anymore. I did this several times with the same outcomee. I tried saving before navigating away from the session screen, but that didn’t help. After several attempts I just saved, closed my designer, re-opened it, and tried to repeat the process, but this time the properties I created were saving.
Interestingly, my designer showed my session with Session Position and Session Meta before I closed, but they are no longer there when I open it. This seems to be indicative of a bug writing where it shouldn’t be, because I don’t know why a session would need a configurable position property
FYI. Still issues in 8.3.4
I raised a support ticket (#188659) and the analyst directed me to this thread. Still having the issue in 8.1.52
I've had my custom props disappear twice now with a power drop in the plant during commissioning (UPS not yet installed in the control room). It seems this only happens if I have the designer open with unsaved changes on any pages and the power drops. I just restored the Session Props from my backup and everything is back to normal. hope this helps, I'm on version 8.3.6.
I had this issue and it somehow dropped twice on me too within the past 3 months. I have saved it and always checked my stuff before closing it. I didn't find a solution but just put my program code up again (it helps that I have it saved in GitHub so I have a backup). The last time I saw this issue was in June so hopefully it does not come back again.
Yeah, we have encountered this same problem with 2 different clients. In total, we have had our custom session properties deleted 3 across 2 projects in the last week. I can't believe that IA has not ben able to pinpoint and fix this impactful bug.
If this is happening regularly enough, it would be great if you could contact support and get them to supply you with the debug module, which adds logging to try to trap this scenario.
