Hello beautiful people,
I had this issue a while ago and asked about it (here). @paul-griffith redirected me there.
All in all, things got smoother and the error only ever appeared when a transaction was opened but there was nothing to commit. Which I fixed easily, by making sure not to open the transaction if there was no query to run.
But a few days ago, things got weird again.
I'm running queries, and I can see in my database that records were indeed inserted just fine, but I get a java.lang.Exception: Error executing system.db.closeTransaction error with this in the stack trace:
Caused by: org.python.core.PyException: java.lang.Exception: java.lang.Exception: Error executing system.db.closeTransaction(5bf23e6b-f299-45c4-8f99-3a3e16a1a5a6)
... 45 common frames omitted
Caused by: java.lang.Exception: Error executing system.db.closeTransaction(5bf23e6b-f299-45c4-8f99-3a3e16a1a5a6)
... 44 common frames omitted
Caused by: java.sql.SQLException: Transaction "5bf23e6b-f299-45c4-8f99-3a3e16a1a5a6" is closed.
To sum it up:
- The data is actually inserted
- I checked that the transaction ids match
- From what I've seen so far this only happens when inserting, not updating.
I'm running 8.17 and can't update.
I'm not sure what to do now.
