Hello, in a module with websockets managed by Ignition Jetty werserver, we are using the following artifact:
        <dependency>
            <groupId>org.eclipse.jetty</groupId>
            <artifactId>jetty-server</artifactId>
            <version>10.0.15</version>
            <scope>provided</scope>
        </dependency>
        <dependency>
            <groupId>org.eclipse.jetty.websocket</groupId>
            <artifactId>websocket-jetty-api</artifactId>
        </dependency>
        <dependency>
            <artifactId>websocket-jetty-server</artifactId>
        </dependency>
        <dependency>
            <artifactId>websocket-servlet</artifactId>
        </dependency>
I try to upgrade them for Ignition 8.1.49,
it works for:
        <!-- Core Jetty server -->
        <dependency>
            <version>12.0.17</version>
        </dependency>
but not with:
        <dependency>
            <artifactId>jetty-servlet</artifactId>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
Could not find artifact org.eclipse.jetty:jetty-servlet:pom:12.0.17 in releases (https://nexus.inductiveautomation.com/repository/inductiveautomation-releases)
I'm not sure I have selected the right new articfact ?
My code with Jetty 10:
import org.eclipse.jetty.websocket.api.Session;
import org.eclipse.jetty.websocket.api.annotations.OnWebSocketClose;
import org.eclipse.jetty.websocket.api.annotations.OnWebSocketConnect;
import org.eclipse.jetty.websocket.api.annotations.OnWebSocketError;
import org.eclipse.jetty.websocket.api.annotations.OnWebSocketMessage;
import org.eclipse.jetty.websocket.api.annotations.WebSocket;
import org.eclipse.jetty.websocket.server.JettyServerUpgradeRequest;
import org.eclipse.jetty.websocket.server.JettyServerUpgradeResponse;
import org.eclipse.jetty.websocket.server.JettyWebSocketCreator;
import org.eclipse.jetty.websocket.server.JettyWebSocketServlet;
import org.eclipse.jetty.websocket.server.JettyWebSocketServletFactory;
    public void createServer(int maxClient) {
        try {
            this.maxClient = maxClient;
            WebResourceManager web = gatewayContext.getWebResourceManager();
            web.addServlet(wsPath, PerspectiveWebSocketServlet.class);
            logger.info("createServer : {} servlet added",wsPath);
            this.executorProcessReception = Executors.newFixedThreadPool(maxClient);
        } catch (Exception e) {
            logger.error("createServer : Exception : ", e);
    public static class PerspectiveWebSocketServlet extends JettyWebSocketServlet {
        public PerspectiveWebSocketServlet() {
        @Override
        protected void configure(JettyWebSocketServletFactory jettyWebSocketServletFactory) {
            jettyWebSocketServletFactory.setMaxTextMessageSize(65536);
            jettyWebSocketServletFactory.setCreator(new PerspectiveWebSocketCreator());
    public static class PerspectiveWebSocketCreator implements JettyWebSocketCreator {
        private final Logger logger = LoggerFactory.getLogger(getClass());
        @Override
        public Object createWebSocket(JettyServerUpgradeRequest jettyServerUpgradeRequest, JettyServerUpgradeResponse jettyServerUpgradeResponse) {
            logger.info("createWebSocket");
            return new WebSocketChannel();
    @WebSocket
    public static class WebSocketChannel
        public Session getSession() {
            return memoSession;
        private Session memoSession;
        @OnWebSocketConnect
        public void onWebSocketConnect(Session session)
            try {
                this.memoSession = session;
                String sessionId = String.valueOf(session.hashCode());
                logger.debug("sessionId = {} - onConnect", sessionId);
                sendMessage(session, createSignalingMessage(MESSAGE_READY, ""));
                logger.error("onConnect : Exception : ", e);
        @OnWebSocketMessage
        public void onWebSocketText(String message)
            String sessionId = String.valueOf(getSession().hashCode());
            Session wsSession = getSession();
            try {
                if (!message.equals("HEARTBEAT")) {
                    logger.debug("sessionId = {} - onWebSocketText - LocalAddress = {} - RemoteAddress = {} - message = {}",
                            sessionId,
                            wsSession.getLocalAddress(),
                            wsSession.getRemoteAddress(),
                            message);
                if (message.equals("HEARTBEAT")) {
                    // réponse au heartbeat envoyé par le client JS
                    onWebSocketText_heartbeat(sessionId,message,wsSession);
                } else if (message.startsWith("STOP")) {
                logger.error("sessionId = {} - onWebSocketText : Exception : ",sessionId, e);
        @OnWebSocketClose
        public void onWebSocketClose(int statusCode, String reason)
            try {
                logger.debug("sessionId = {} - onWebSocketClose", sessionId);
                stopPipeline(sessionId);
                logger.error("onClose : onWebSocketClose : Exception : ", e);
        @OnWebSocketError
        public void onWebSocketError(Throwable cause)
            //super.onWebSocketError(cause);
@paul-griffith help me a lot:
