Works great!
How would you use this in perspective to show live status of containers(?):
I am thinking a gateway event timer script. Then write to a dataset tag. But then the script would init every time, which is unnecessary since the token is valid for 8 hours?
Parallel to the status being updated. If I make buttons in perspective to start/stop containers. Should I run this script directly, or use the already obtained token. In the latter case I must store the token somewhere; normal tag database, or session custom props?
