Ignition Perspective iOS App
Thanks for following up. So the issue was with a component, not that Perspective had read-only access. Yes, QR codes work and we have to generate them with third-party tools. Automatically displaying them on the gateway webpage would be slick.
This is something we're exploring internally :+1:
Thank you so much for this !
Hello,
Regarding to this post I think I’ve done everything right but still getting invalid host when manually searching for gateway, i also created an inbound connection in the firewall under the port 8088 but still getting the same invalid host and I’m unable to open the gateway in my phone browser, any help please !!
Ps: I’m using an android device
Check if you android is on same network as gateway.
Try doing this once, turn ON hotspot of host PC and connect your android to it. Try accessing gateway.
I got the same issue before I was not able to connect with the gateway and added a new rule for inbound and outbound worked. Thank you for providing an effective solution
Thank you so much. I had the same issue and your solution worked perfectly for me.
Thanks, it’s working
